Is this the case also with fapt ladder for dos, runing on a standard pc with serial port?
I try to download a ladder i wrote for my machine/compile with a fapt ladder on a standard pc with serial port but when i press F6->F3 i got a red message on the pc screen
"Port initialize error serial port communication is impossible"
The pc which the fapt ladder is running was able to receive the parameters i send from the OM-F controller, so the cable->serial port is ok.
The cable is just a three wire connection, do i have to use the 5 wire cabling, with handshake, or this is not importand?
Any help will be appreciated.
Try powering off the PC and don't start any other communicating between the machine and laptop. If I start my PC without anything connected to the serial port I still don’t get that alarm. Sounds like the serial port is tied up with whatever you did last with it. Or you have a blown port. Did you try to go both ways with communicating?
It's a standard ibm compatible pc running pure msdos 6.22, nothing else.The serial port is checked, because i could receive the parameters send from CNC.
You can receive the parameters but can you send? Fladder needs to see it go bothways.
Ok i did not check that. I will do it on Monday and lets you know. Thanks for the tip.
I finaly managed to send the PMC programm via serial. The problem was that the ms-dos directory was not shared and for some reason i don't know the fladder gould not initialize the com port.When i include to the autoexec.bat the command PATH=C;\MSDOS;C\FLADDER it worked. So i was finaly able to send the *.#ex file to the OM-F.:wee:
GEAST1967
TWO TO ALL
COULD YOU HELP ME WITH THE STEPS YOU FOLLOWED TO REACH YOUR SUCCESS
I WANT TO DO THE SAME ON MY LATHE THANK YOU AND I HAVE THE FAPT LADDER II SOFTWARE ON WINDOWS 98
THANK YOU
Yes i can help you, but what i did was with Ladder I.
Dragonbikes, please clear your inbox, i can't send you pm.
READY
[email protected]
Thank you
hi Guys
I need to edit my GPP file to enable block numbering. I have changed some statements but it is not work properly. please suggest something to do it properly.
here is the picture of my GPP file and program after editing
Yes. Tell me what you need.Hi, could you help me please with the steps?
Thanks. I had already been able to do this. But how convert bin files to #ex, or how download ladder direct of cnc... on fanuc 0 series.
I use this app, but it doesn't work.
I send the two binary files OE1 and OE2 to a person here in the thread you will find his email, and he did the conversion. I don't think fapt ladder I can do it.You need to combine the two files OE1 and OE2 to one binary file and then make it .#ex
