586,100 active members*
2,646 visitors online*
    Sep 2012
    Unhappy SURFACE JOINT
    HELLO EVERYBODY I need help stitching or jointing two surfaces together so i can machine them as one surface. is there a method to unite or combine two or more surfaces into one in mastercam x5 any advice will be appreciated thank you for your time and knowledge.
    May 2004
    4519
    Only thing I know is to use Solid > Create solid from surfaces. Be sure to put on a new level and not delete your old surfaces in case you need them again.
    Jul 2003
    263
    extend the surfaces until they intersect then use the trim surface to surface function
    If you can ENVISION it I can make it
    cadcam Guest
    There is no direct tool to join surfaces. without seeing what to surface shapes you are trying to join, I find it hard to give direct answer.
    txcncman Guest
    Quote Originally Posted by cnc-king View Post
    I am sure I will be corrected at some point, but this will only result in 2 surfaces. I think the original poster was wanting only 1 surface made from 2. I think the Surface > Create from solid method I mentioned will make 2 surfaces into 1 if they lie in the same plane.
  1. Joint for ATS chuck
    By maximusek in forum Uncategorised MetalWorking Machines
    Last Post: 10-15-2011, 06:44 PM
  2. Help with joint following error on rapids?
    By BWay in forum LinuxCNC (formerly EMC2)
    Last Post: 12-25-2010, 07:45 PM
  3. Joint following error
    By Gads in forum LinuxCNC (formerly EMC2)
    Last Post: 04-11-2008, 03:02 PM
  4. help with screw joint in cosmosmotion
    By posix in forum Solidworks
    Last Post: 01-17-2006, 12:40 PM
