586,075 active members*
4,034 visitors online*
Results 1 to 12 of 12
    Mar 2007
    215
    Fixture Table Warping
    Hi guys, I machined the following fixture; 1020 Steel; 19 inches long, 6 inches wide and about .625" thick. As you can see from the pictures, over time the table begins to bow upwards in the middle. We have tried the same table 1" thick and the same problem still arises. I am at a loss as to what is causing this, any thoughts would be appreciated. I should mention that it is being held between two 6" kurt vises set 4" apart.
    Thanks;
    CM
    15362
    Crashmaster
    Stress relieving the steel before you mill it will help, also the type of cutter you are using to cut it, you can get/buy the steel already in a stress relieved state
    This is normal for steel & other materials that have stress in it from the manufacturing process, to warp & move around when being cut
    Mactec54
    May 2004
    4519
    As mentioned, stress relieve the material before machining. Also, machine equal amounts of material off both sides.
    Mar 2007
    215
    Thanks for the info guys. Is there anyway to stress relieve steel without heating it or is that generally the only way to do it?
    Jul 2007
    1602
    Cutting the same pattern on the bottom of the plate might suffice since it would somewhat balance the stresses.
    Could you get away with using different material for the fixture? Cast aluminum tooling plate comes to mind.
    bob
    Jul 2005
    12177
    6" wide and finished at about 5/8"; you should be able to make this out of a piece of 6" x 1" hot rolled steel which will solve your warping problems.
    May 2004
    4519
    Quote Originally Posted by Crashmaster View Post
    There are also processes to stress relieve material with vibratory stress relief and with shot peening. These seem to be only effective in materials with smaller cross sections.
    Mar 2007
    215
    I think aluminum tooling plate maybe on the high side of cost for us for this part. We are getting pricing now. Geof, we have only dealt with cold rolled here, is there any machining issues with hot rolled? Generally doesn't hot rolled have a bit of carbon scale on it?
    Jan 2004
    3154
    Yes it does.
    That is why you start with 1".
    Needs 100% machined and should have equal amounts taken off each side.
    Even with HR, perfection would dictate a rough machine - stress relieve - finish machine process, but even with just straight machining will be much better that CR
    www.integratedmechanical.ca
    Mar 2007
    215
    Great. Thanks to everyone who responded. Learn something new every hour!
    tacdriver Guest
    My two cents, by the time you rough, stress relieve, and finish, you might as well have bought aluminum. We use a lot of fixture plates with the Jergens clamps / bushing system. They work great. We just put in a cheap overhead electric hoist and trolley so now we can lift the pair of double vises (about 250+ lbs) / switch to a pair of single vises / switch to fixture plates without compressing a disk in our backs. Works great.
    The cost of the cast aluminum plate (can't recall the number off the top of my head right now) is not that bad. It's already finished to .005" so we just run a face mill where things are going to be sitting.
    Feb 2010
    3447
    3/4" Alcoa Mic 6 tooling plate 12"x48" off ebay is about $279 and 33 to ship. You can get a shorter piece for a lot cheaper. Many different sizes. I'd check it out.
    Mic 6 Cast Tooling Aluminum Plate 3 4" x 12" x 48" | eBay
  1. 303 stainless warping
    By fishcat in forum RFQ Feedback
    Last Post: 10-11-2011, 09:05 PM
  2. Brass warping during milling
    By Bill Ataras in forum MetalWork Discussion
    Last Post: 10-08-2011, 04:48 PM
  3. Wood warping after milling
    By SteveS in forum WoodWorking Topics
    Last Post: 02-23-2011, 04:53 AM
  4. 304 sst warping
    By jim@edmik in forum MetalWork Discussion
    Last Post: 12-22-2008, 03:13 AM
  5. Help with warping material
    By snaggletto in forum MetalWork Discussion
    Last Post: 04-09-2005, 04:22 AM
