586,082 active members*
3,602 visitors online*
    Feb 2011
    423
    cleaning equipment
    I pray that none of my fellow members ever have to deal with a shop fire like I
    have. With that being said I am trying to find a process other than media blasting to prepare some of the salvageable equipment for painting.
    Have any of you had to do this or know of an alternate process for sheet metal and cast iron prep?
    thanks,
    Scott
    May 2004
    4519
    Are you only cleaning? Or do you need to remove burned paint?
    Feb 2011
    423
    The fire was mainly in the overhead vinyl faced insulation. Most of the paint has not bubbled but it is blackened. The only thing that I have come up with so far is trying oven cleaner. I do thank you for your response.
    May 2004
    4519
    Have you considered or inquired about dry ice blasting? From your description, I think it would work for you.
    Feb 2011
    423
    I'm not familiar with that process but will study that tonight.
    Thank you!
  1. USED CNC EQUIPMENT
    By ptd in forum News Announcements
    Last Post: 09-16-2011, 04:20 PM
  2. CNC EQUIPMENT
    Last Post: 07-07-2011, 03:09 AM
  3. What equipment to get?
    By outsider787 in forum Benchtop Machines
    Last Post: 01-25-2011, 05:02 AM
  4. On CNC equipment
    By TomHay in forum CNC Wire Foam Cutter Machines
    Last Post: 03-17-2006, 03:33 PM
