Originally Posted by
jimwjr89
Thanks for your reply. As i am new to the swiss machines I have another question you may be able to help me with. Since the collets on this machine do not have any keyways for location are htere any problems with them moving at all and losing orientation once you get it set? Thanks for your help
It is possible that you could put in a "non-keyed" collet and sleeve, get it oriented and run-out thousands of parts with out loosing the orientation.
It's also possible (and highly likely) that you will loose the orientation at which point, mayhem and destruction will ensue.
I always have the collet keyed to match the keyed collet sleeve, we made our own system, but Citizen has a decently priced "off the shelf" sleeve option, that I would recommend.
Good luck.
Control the process, not the product!
Machining is more science than art, master the science and the artistry will be evident.
