586,080 active members*
3,715 visitors online*
Page 2 of 2 12
Results 21 to 25 of 25
  1. #21
    May 2004
    4519
    Quote Originally Posted by Spinnetti View Post
    The stuff I do is a few at a time, not production work, so a bit of overhead beats expensive fixturing.... Back to the shop to try out some of these ideas... where do I get little screw jacks?
    Use some of your clamping studs and nuts.
  2. #22
    make em , clamp studs and nuts as tx stated , or bolts that are threaded into some stock . The #1 thing to remember is to not not loose the parts position while jacking or clamping , so a dial indicator is handy for this type of thing . Let the jack raise the part a few thou , and the clamp should pull it back into place
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
  3. #23
    Jul 2006
    525
    PS, was going to do 3d toolpaths originally, but don't have the software for it... using HSMexpress which is 2d. Hmmm.. just tried "trace" which seems to do it, but would I use a ball end cutter for that or would a flat one work?
    Trace wont (directly) give you the toolpath you're looking for. It doesn't compensate for tangential inaccuracies, and simply places the tool tip on the edge you're selecting.
    You could, however, build an offset surface that compensates for the tangential inaccuracy, and use trace on THAT surface.
  4. #24
    Dec 2003
    673
    I think I'm going to do the problem cut first, keeping the most mass available for damping... Ordering stock again next week.
  5. #25
    Sep 2012
    1543
    Good choice
Page 2 of 2 12
  1. Lathe Workholding
    By jheers in forum MetalWork Discussion
    Last Post: 02-26-2013, 03:05 AM
  2. Workholding Suggestions Please
    By UKRobotics in forum Uncategorised MetalWorking Machines
    Last Post: 11-24-2010, 02:08 AM
  3. Online Workholding Shop for Workholding
    By mtadirect in forum News Announcements
    Last Post: 08-19-2009, 03:37 PM
  4. WORKHOLDING
    By JMECKES in forum MetalWork Discussion
    Last Post: 08-03-2009, 04:31 PM
  5. workholding
    By buggie in forum Work Fixtures / Hold-Down Solutions
    Last Post: 03-27-2009, 10:49 PM
