586,100 active members*
2,737 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > NM-145 owners, need your help
    Feb 2010
    371
    I somehow managed to corrupt my Mach3 xml file I had for my 145. Now when I try to start my spindle, I get a message from mach that it is using a minimum PWM rate, (or something like that), and the spindle turns very slowly. My mill is the non-torus version, 2011-early 2012 era. Could someone post their xml file? I tried the "Mach 3 Mill NM-145.xml" posted a while back, but I get the same error.
    I also tried the xml file that is posted on the Novakon site, but for some reason, Mach3 locks up the computer solid while loading when I try to use it.
    Eric
    Sep 2010
    72
    PM me your email, I can send a couple
    Feb 2010
    371
    Thanks guy, I'm all set now!
    Jan 2012
    469
    Doesn't Mach3 save backups of the config file on a separate folder?
    Feb 2010
    371
    Quote Originally Posted by TiagoSantos View Post
    Sheesh! You're right. I was working off fresh install so the backup folder hadn't been created yet. I completely forgot about it.
  1. 770 owners
    By howecnc in forum Tormach Personal CNC Mill
    Last Post: 03-03-2013, 04:40 PM
  2. ??? For X4 - X5 Owners
    By Bob La Londe in forum Syil Products
    Last Post: 06-04-2012, 07:12 PM
  3. KX1 Owners LOOK!
    By deanler in forum Benchtop Machines
    Last Post: 06-27-2010, 01:11 AM
  4. Any LMS CNC owners out there?
    By slawsonb in forum Uncategorised MetalWorking Machines
    Last Post: 05-15-2010, 04:09 PM
  5. Any CS 250 Owners out there?
    By Polishpiper in forum Mori Seiki lathes
    Last Post: 06-15-2009, 11:40 AM
