Is it possible to force a milling operation to start in a hole
I have a small part (2.5" x 1.5" x .5) that I am tool path-ing. In the center there is a 1" counter bore on top of a 3/8" through hole.. There is a small space off of the 1" counter bore that also needs to be milled.
I have some new Niagara roughers that I picked up recently I would like to try use. They are not center cutting. I would like to start milling the 1" counter bore inside the 3/8" hole to avoid plunging. I have a 5/16" or a 1/4" that I was going to use for this. Is this possible with V25 and how would I do it?
Put a point in the center of your hole.Select it it as your start point.
JSYK,if you Ramp,you can do it with out center cutting end mill.
Ah, I figured it was something like that. With your hint I went off looking how to do that, it's the Drill Tip Positions under the feature tree. The trick is to set the point that it needs at the __BOTTOM__ of the hole you want to enter through. The tool path will be computed from that point upwards.
I tried using Ramp, but every time I unchecked the "Center Cutting Tool" check box it would only leave the Plunge option up and it was auto-checked.
We use cookies to optimize our website for you and to be able to improve it continuously. By clicking the "Accept" button, you expressly agree to the use of cookies. For further information on cookies, please refer to our privacy policy.
