586,076 active members*
3,737 visitors online*
IndustryArena Forum > CAM Software > Mastercam > What's the best way to machine an opened slot?
Results 1 to 13 of 13
    Mar 2012
    I wonder what is the way you guys use to machine an opened slot? Like what's shown in the pic.
    May 2004
    4519
    How would you do it on a manual mill? Program it in MasterCam to do it the same way.
    Jan 2004
    3154
    I would use a milling machine (knee mill)
    www.integratedmechanical.ca
    Aug 2008
    292
    boundary box
    Quote Originally Posted by youyou43 View Post
    it is called a boundary box. draw a rectangular box over hanging your open slot as far as you need. the rectangular box is used to create a tool path that stays in the box but machines your open slot.
    it can be draw on a different level / layer so the boundary box can be made invisible when you are done with it.
    Jul 2003
    263
    i assume you want to use MasterCam since you are in the MC forum.
    Use the 2d high speed peel mill routine using the slot edge geometry to drive the tool set your exit and entry distance.
    If you can ENVISION it I can make it
    Mar 2012
    Quote Originally Posted by DMF_TomB View Post
    K. That's the way I do usually. Thanks!
    Mar 2012
    Quote Originally Posted by txcncman View Post
    So, usually what I do is to surround the slot with an rectangle box and use pocket. I just wondered if there is a way to do this type of slot by using two parallel lines only. But sounds like there is none.
    May 2004
    4519
    I could program a slot in MasterCam to use only 1 line. It all depends on how you want cutting to go and how much control you want over finished size.
    Mar 2012
    If you meant using contour on one line then I will have no control on the opposite side.
    May 2004
    4519
    Exactly. Sorta. Unless you use 2 diameter offsets. Or maybe run the line one direction for one side of the slot, then run the line the opposite direction for the other side of the slot allowing for Amount to leave XY to compensate.
    May 2004
    4519
    Maybe this will help:
    Attached Files Attached Files
    May 2010
    132
    Quote Originally Posted by cnc-king View Post
    There are many ways to do it, but this is my preferred method as well.
    - Vtpros (mastercam instructor)
    Apr 2003
    3578
    I use peel mill or I selct both side of the slot and tell to cut by depth.
    Cadcam
  1. V24 crashing when opened
    By nlh in forum BobCad-Cam
    Last Post: 01-07-2013, 12:58 AM
  2. Machine continues to run when spindle cover is opened
    By TMashino in forum Tormach Personal CNC Mill
    Last Post: 01-30-2009, 11:53 PM
  3. move card slot to machine front panel
    By krfrea in forum Sharp CNC
    Last Post: 12-22-2008, 04:22 PM
