On most controls when the drive or controller would activate a move and not 'see' an encoder response, the drive would shut down or error.
The difference between anticipated position and actual is known as Following Error.
There will always be some in a servo move, but if out of the pre-determined range, the error will occur at this point.
Disconnecting the encoder is one form of simulated encoder failure.
I have no exact knowledge of what Gecko do in this case, but I would expect something along these lines?
Al.
Albert E.
