586,818 active members*
6,128 visitors online*
Results 1 to 3 of 3
    Dec 2006
    need some advcie on motor control
    Dear forum,
    We're building a camera rig for animation that uses stepper motors to move the camera through 3 axes; mechanically this is fairly straightforward but we now need software to generate pulses (not g-code) to fire up each motor's microstepping board.
    Any ideas?
    Dec 2003
    24223
    It almost sounds like you can use a hardware solution, a settable pulse generator, if you need to make the changes, either mechanically or programmed,
    It could be done with a PIC or a PLC.
    Do you need interpolated moves?
    Do you need to program speed also?
    Al.
    Albert E.
    Jan 2006
    245
    Really depends on the type of moves you are making, will you be moving the camara to fixed locations, that are to be stored in a DB, or will you be manually moving each axis with a jog or by a joystick?
    Need a bit more info on the application really.
    Quote Originally Posted by Jonward View Post
    Dear forum,
    Any ideas?
    Motion Control Products Ltd
    www.motioncontrolproducts.co.uk
