586,635 active members*
3,304 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > Need Post for DMU 50 EvO with TNC426 control
    Jan 2011
    Hi, Can anybody help. I need an EdgeCam post for a Deckel DMU 50 eVolution with a Heidenhain TNC426 control. It could be different TNC control I'm sure I could make any alterations on that. I've tried doing a post from a template and am almost there except it won't run the B axis properly. It can't do anything to get around the fact that when you rotate B axis 180 deg, the table actually at 90deg because of the 45deg nutated action. I've modelled the machine up and the graphics work fine if I index to the front face which would be a B+180 C+0 move, but when I post it, it gives me B+90 C+180 because it think B is just rotating around Y and if B when to +180 it would turn the table upside down. Hope somebody can help, EdgeCam haven't been much help so far.
    Mar 2007
    53
    I found this by accident the other day,
    Its an Edgecam reseller in the Netherlands.
    Check with your local edgecam support and
    see if they can get a copy of the DMU 50 EVO,
    or at least the machine graphics setup / definition.
    Machinesimulatie voor frezen, draaien en draaderoderen van Widenhorn: EdgeCAM
    May 2010
    Hi Neil,
    I need too almost the same postprocessor for EdgeCAM:
    DMU 50 evoLinear + HH iTNC530
    or
    DMU 60 evoLinear + HH iTNC530.
    Did you obtain that post??
    jonksey Guest
    Hi
    I've DMU 70V
  1. TNC426 file transfer
    By KevinV_MEI in forum Bridgeport / Hardinge Mills
    Last Post: 01-20-2011, 05:45 AM
  2. VMC1000/22 Mould Master TNC426
    By mcwmah in forum Bridgeport / Hardinge Mills
    Last Post: 01-30-2008, 01:20 PM
