Originally Posted by
691175002
I originally managed to pack the balls on a 1605 screw as per the youtube video. Was slow but not bad.
On my smaller machine I got 12mm screws with long machined sections on each end and it was literally impossible to put the balls in on the screw. I read somewhere on cnczone where they suggested putting some goopy, very thick grease in the ballnut and sticking the balls into place then rolling the nut onto the screw in one go.
Honestly, it was easier and faster than the original method and I plan on doing this exclusively in the future. You need to be careful when inserting the screw at the end (or you will push the balls out of the nut) but it isn't that hard.
Did the same thing with my short 1605 ballscrew with machined ends. The youtube idea is fine as long as one end is straight cut. Placed the ballnut with the races packed with grease in the freezer for 15 minutes then packed the circuits with the balls 25 each circuit and carefully screwed the nut in to it. As far as I'm concerned from now on that the only way I'm going to this..
Best..
Forget about global warming...Visualize using your turn signal!
