586,058 active members*
3,435 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Series 1 BOSS 5 X Axis Dead, still dead after new transistors
    keebler303 Guest
    I accidentally fed my 2" face mill into some HRS at 60" per minute. My X axis stopped dead in it's tracks as soon as the face mill hit the stock. I tried jogging and it did the jumpy vibration thing like an output transistor was blown. I shut down for the night. The next day, I checked the fuse for the X axis and it was blown (FU12). I replaced the fuse and tried again. Same problem. Then I measured x axis phase voltages at the control and noticed one leg (X4) was significantly different from the others and the known good Y axis motor. I traced X4 back to the lowest transistor on the X heatsink. I replaced only that transistor with a new 2N6547. This did not fix the problem. I then replaced the remaining 3 transistors and still not fixed. I tried swapping SMD boards and the problem stays on the X axis.
    By not replacing all 4 transistors at once could a remaining bad one blow the new one?
    What else is there that would give me the symptom of a blown transistor?
    What else can I check?
    Matt
    Feb 2006
    30
    Matt, can you make a comment about your machine issue...did you fix it ?...as I have exactly the same condition with mine. (Series 2, ex Boss 6, Mach 3, BOB).
    Regards.
    Jerry
    Jan 2006
    2985
    Jerry
    I replied to your PM. Long story short, I gave up and installed a Gecko G203V on the X axis only.
    Matt
    Feb 2006
    30
    Hi Matt.
    Couldnt find your reply in my PM, anyway thanks for your help so far...
    Jerry
  1. Bridgeport CNC Series II Boss 6 is Dead!
    By grigsby in forum Bridgeport / Hardinge Mills
    Last Post: 06-18-2016, 09:04 AM
  2. Mazak M5 DEAD BATTERY -DEAD CONTROL
    By tired_iron57 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-06-2012, 07:35 PM
  3. Series I Boss 5, All axis dead
    By timprebleco in forum Bridgeport / Hardinge Mills
    Last Post: 01-31-2009, 06:49 PM
  4. Boss 6 Y axis dead
    Last Post: 01-01-2009, 03:59 PM
  5. BP Series I CNC - z axis dead
    By jho5820705 in forum Bridgeport / Hardinge Mills
    Last Post: 10-26-2006, 09:42 PM
