586,051 active members*
3,839 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Simple design - hard to fabricate?
Results 1 to 9 of 9
    Feb 2013
    11
    I need to have a couple parts fabricated and would appreciate input (I know next to nothing about metal machining). Any comments you have about material, finishing, modifying sizing to increase ease of machining, etc would be appreciated
    The part I want to replace is steel (mild steel I suspect). The part is one side of a press that squeezes thin plastic and embosses it with a pattern. I want to replace the part in order to change the pattern.
    The part is 122 x 20 x 30mm (aprox 4.75" x .75" x 1.25"). The height of the pattern on the part is 0.5mm tall (aprox .02")
    I was hoping to have 1mm as the spacing in and around each raised piece in the pattern.
    The surface of the pattern needs to be a flat plane. The pattern itself doesn't require an excessive level of accuracy - I'm assuming +/- .005" is reasonable to achieve?
    Anything obvious that I should change to make machining easier? Standard units instead of metric maybe?
    New pattern design (in mm) :
    Original design:
    Jun 2012
    516
    That will require tooling that most people won't keep in their shop. Go to mcmaster carr and lookup a 0.025" diameter endmill and see the price - then figure you might break a few. Someone with an EDM sinker could do that part for you - will be pretty pricey though. Good luck! If its gonna be an EDM project, steel won't be trouble. On a mill with those fancy small / easily breakable endmills its going to be better in aluminum.
    Sep 2010
    16
    It would probably be easier to mill with a slitting saw than a tiny endmill.
    Mar 2006
    2712
    Ganged slitting saws for spaces and end mill or? to remove larger areas as PJRitz suggested. Used that method for serrated sealing dies in packaging machines.
    Dick Z
    DZASTR
    Sep 2008
    117
    Relatively simple on a surface grinder. Somewhat time consuming. I would guess about 3-5 hours.
    Gene
    Feb 2013
    11
    Thanks so much for the input. Based on that input I've:
    - Adjusted dimension to best match to inches
    - Adjusted the pattern based on 1/32" cuts from a metal slitting saw
    - Resized pattern to fit on a stock 1/2" x 1" bar
    Would there be a huge difference in cost/time between using 4140 and tool steel?
    Any other comments?
    Revised drawings:
    Feb 2013
    11
    I've done a final redesign based on the feedback.
    If anyone is interested in fabricating these parts please let me know. I've just posted in the RFQ section in Canada and the USA (these should easily be shipped to Vancouver BC or Bellingham Wa).
    Thanks again.
    Rusty13
    Apr 2004
    5737
    I'd say find someone with a horizontal mill. While making all those slots with a 1/32" endmill would be a nightmare on a vertical mill, it would be a piece of cake for a 1/32" kerf saw-blade type cutter in a horizontal mill.
    Andrew Werby
    www.computersculpture.com
    Jan 2007
    1795
    try to post on the tormach section..
    a slitting saw the solution, however with cnc some migth takes on this..
    timeconsuming, however easy to programming
    you can find endmills at bitsbits.net or ebay...
  1. Simple THC design
    By Volker in forum LinuxCNC (formerly EMC2)
    Last Post: 12-07-2012, 02:38 PM
  2. Strange Results with Simple Design
    By RPCElectronics in forum Vectric
    Last Post: 05-28-2012, 12:57 AM
  3. Replies: 6
    Last Post: 07-07-2011, 08:02 PM
  4. How to start 1-Axis really simple design
    By Timbersmith in forum DIY CNC Router Table Machines
    Last Post: 02-06-2008, 02:01 AM
  5. Help with simple piston Design
    By inmemarcos in forum Mechanical Calculations/Engineering Design
    Last Post: 02-14-2006, 10:03 PM
