586,036 active members*
3,654 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > Metal cutting saw blade on wood band saw?
Results 1 to 7 of 7
    Jun 2012
    23
    HI. I have 10" inch band saw and I am planning to cut thin steel. I only use this wood band saw in resawing some woods but I am not sure if I can work some metal or steel on it. I want to know what speed should I set up and what else should I need to do. Thank you.
    Jan 2004
    3154
    I had a machine like this many years ago.
    We had a 5:1 reduction gearbox on it to get the SFM low enough for steel cutting
    www.integratedmechanical.ca
    Jun 2012
    23
    I think I should try lower 300 SFPM . I have to cut mild steels. I ordered a pair of hard back carbon saw blades. Lets see how it will work.
    Jan 2004
    3154
    You will likely be disappointed with carbon blades, especially if your SFM is high. It can't handle the heat.
    Bi-metal are reasonable and kick the crap out of carbon (saves money in the long run).
    Mild steel at 300SFM with bimetal is perfect.
    Try a blade like Starrett Matrix II or Bahco EasyCut.
    Thin metal go with 10/14 TPI - .375 to 1 go 5/8 TPI - over 1 go 4/6
    Jun 2012
    23
    Thanks for your input . I'll take your advice! I was really thinking about bi metal. I already ordered Haltbar carbon
    blades. If it won't work well , I'll get the bi metal blades.
    Jun 2004
    6618
    I have a Starrett bimetal blade on a little Craftsman bandsaw without reduction. It cuts plastics and metal, but only brass and aluminum. I have accidentally cut a piece of steel and it almost instantly ruined the blade.
    Those aren't cheap blades to destroy before the job even gets done.
    You might consider one of the cheap hand held bandsaws from HF.
    Lee
    Jan 2004
    3154
    I run my vertical at 300SFM all the time with Bahco Cobra 10/14TPI.
    That is too fine a blade if you are cutting heavy stock as a rule of thumb.
  1. band saw blade tpi ?
    By SSN Vet in forum Benchtop Machines
    Last Post: 07-04-2010, 09:51 PM
  2. Band Saw Blade Inquiry
    By JWB_Machining in forum Uncategorised MetalWorking Machines
    Last Post: 11-08-2008, 07:20 PM
  3. Band Saw Blade TPI?
    By JWB_Machining in forum MetalWork Discussion
    Last Post: 10-30-2008, 01:43 PM
  4. Harbor Freight Band Saw Blade Slipping
    By barkster in forum Benchtop Machines
    Last Post: 04-26-2004, 06:20 AM
