586,123 active members*
3,324 visitors online*
Results 1 to 6 of 6
    May 2005
    925
    Question Identifying a servo motor
    Hello folks, Im posting looking for help identifying these motors, they are hooked to a small CNC mill, I have absolutely no reference about them, just my educated intuition. I think these are servos because they have a 4:1 reduction and have encoders on their back.
    Here are photos of the units:
    Both are NEMA34 mount
    One is square, 8 wires coming out of it, 2 sets of the same color
    the wires go to a connector:
    4 of the wires are hooked together, if this where a stepper, doing this would prevent the unit from turning, or am I wrong?
    The other is round, same US Digital Encoder on the back:
    This also has 8 wires all different colors, but the connector is connected in the same fashion:
    These are connected to a small board that looks like some sort of protection (has 4 diodes) since its not wired like a rectifier
    also attached to this little board is this power resistor that looks like an energy dump:
    The driver is homemade and its made out of a set of 8 darlingtons BU941ZP and three 74HC00 logic gates.
    So my conclusion is these are brushless DC servos (but I may be wrong of course)
    I would like to know how to determine the wires and if possible determine their voltage, so I know if I can use them with any known servo drive.
    Thanks a lot in advance!
    Pablo
    ● Distribuidor Syil en Argentina ● "www.syil.com.ar" ●
    Jul 2003
    1754
    My guess is a 8 wire stepper hooked up like the first example here
    Stepper Motor Connections - Motion Control Information
    Notice 4 wires are hooked together to V+
    and that would make sense why there are 8 darlingtons as that would give you bipolar switching..
    sam
    May 2005
    925
    maybe, but if these are steppers indeed, I wonder why they use a 4:1 reduction, that would be counter productive.
    Also, on the square motor, there are two sets of cable of the same color, one set, all the 4 wires are hooked together, wouldn't this prevent the motor of turning due to the induced current?
    May 2005
    925
    upon further reading, maybe these are steppers wired unipolar as you told me, unipolar has less initial torque but the torque curve is flatter, maybe this explains the 4:1 reduction
    May 2005
    925
    Sam, today I was able to remove the motors from the machine and you were right, these are steppers. The obvious confirmation came when I turned the shaft and felt the steps
    Already deduced the wiring but I could use some help regarding how to determine their inductance.
    Pablo
    Sep 2005
    322
    To be pedantically correct, they are steppers being used as servos (since they have feedback). Sounds like someone did an interesting sort of roll your own CNC...
  1. Newbie Identifying Servo Motor
    By Rencio7 in forum Servo Motors / Drives
    Last Post: 10-25-2011, 09:42 PM
  2. Need help identifying a couple servo motors
    By praetor in forum Vertical Mill, Lathe Project Log
    Last Post: 10-15-2009, 09:21 PM
  3. Help identifying servo
    By Wolfmarsh in forum Servo Motors / Drives
    Last Post: 03-12-2009, 02:08 PM
  4. Identifying SEM servo motor torque
    By boringmill in forum Servo Motors / Drives
    Last Post: 12-27-2006, 05:22 AM
  5. Help identifying servo motor
    By Corvus corax in forum Servo Motors / Drives
    Last Post: 10-26-2005, 03:34 AM
