586,077 active members*
4,009 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > chip load formula - how does bit dia. affect rpm in the calculation?
Results 1 to 14 of 14
    Apr 2008
    80
    To determine feed rate, if our goal is a chipload between .015" - .020" (thickness of chip), the formula says chipload = feedrate divided by (# of flutes x RPM).
    What's missing from this equation is the relationship of RPM to bit diameter.
    Can anyone help me complete the formula? I'm trying to maximize my tool life. Most of my wear and tear occurs cutting wood products.
    Apr 2004
    5737
    Any bit has a maximum size of chip it can make. A bigger bit won't necessarily make a thicker chip, but it's capable of doing that. Yes, the flutes of a bigger tool will be traveling at a slightly higher speed in relationship to the material than those of a smaller one, but that doesn't affect the chip thickness. I think the formula has everything you need, if your tool is capable of cutting that thick a chip.
    Andrew Werby
    www.computersculpture.com
    Apr 2008
    80
    Thanks Andrew - I create a lot of artwork/sculpted items in my business, which leads to a range of diameters from 1/16" diameter to 1" diameter tooling. The speed at the outside of a half inch bit must be significantly more than a 1/16" bit.
    That said, I just did a test using the formula as-is on a half" bit and produced .017" thick chips, so it certainly worked out well after all! Nicholson Design - The Fine Art of Computer Carving
    For any specific style of bit, the chip load will be different for each diameter.
    If you have two of the same model bit, but one is 1/8" and one is 1/2" diameter, the 1/2" bit will have a much higher recommended chipload.
    If you want to maximize tool life, you need to cut as fast as you can, without cut quality suffering.
    Apr 2008
    80
    Ger, I have been gauging my feedrates by looking at my chip size (and finish quality) during the past 4 years. Almost all of the work I've been doing has been one-offs. At this point I'm getting into production work, where tooling wear becomes a much bigger issue. When you note "recommended" chip load, does this suggest that tooling companies will have chip load ratings for all tools, or is there a table that machinists refer to?
    Yes, they should, but not all do. Onsrud has the most comprehensive list I've ever seen. https://www.onsrud.com/plusdocs/Doc/...ode=FeedSpeeds
    Dec 2010
    634
    In the actual chip load calculation, bit diameter doesn't come into play. e.g. Whether you've got a 1/2" tool or a 1/16" tool (let's say two fluted), if you move .001" in one tool revolution, you will cut off .001" of material with a chip load of .0005" irrespective of the diameter of the tool. This is not to say that tool diameter doesn't matter, it just doesn't enter into the calculation of chip load.
    Bit diameter is a factor in the calculation of "surface feet / min" or SFM. This is the speed at which the edge of the tool travels with respect to the material you're cutting. Different materials and bit coatings can dictate different optimal SFM.
    -Andy B.
    http://www.birkonium.com CNC for Luthiers and Industry http://banduramaker.blogspot.com
    Nov 2010
    13
    Dec 2010
    634
    I like this one as it has all the parameters and it will solve for anything: Milling Speed and Feed Calculator
    -Andy B.
    May 2006
    42
    Most chip load charts or calculators are based off of ½”tool diameter cutting ¾” thick material.
    Soft Plastic: 0.004-0.012
    (very narrow chip load range for good finish)
    Incorrect chip load will often be indicated by visible knife cuts or meltback of plastic.
    Proper cutting will produce a curled chip
    Hard Plastic: 0.003-0.009
    Incorrect chip load will be indicated by visible knife marks, cratering or meltback.
    Proper cutting will produce a block or lightly curled chip
    Wood/Wood composites: 0.004-0.040
    (very broad chip load range) recommend: .015-.030 range nominal
    Incorrect chipload will appear in quality of the cut.
    Solid Surface: 0.002-0.015
    Aluminum: 0.002-0.015
    Phenolic: 0.003-0.005
    Tools less than ½” diameter reduce chip load 20% per every 1/8” of diameter
    Tools greater than ½” diameter increase chip load 20% per 1/8” of diameter.
    Chip load is reduced as depth increases (by 25% each time the depth is doubled)
    EX. Increasing from 3/4" to 1-1/2" DOC - decrease chip load by 25%
    Aug 2013
    28
    Re: chip load formula - how does bit dia. affect rpm in the calculation?
    I'm just starting to figure this stuff out. I am cutting circular pockets in 3/4" poplar wood. The circular pockets range from 3/8" to 1 1/8" and go 0.625" deep. I have to double check, but I have been using a 2 flute, upward spiral HSS bit at 12,000 RPM (max of spindle) at 25 inches per minute. My ramp speed is about 0.125 per pass. So I figure it should cut easy but I manage to get vibrations and cuts are not 100% (of course, it is poplar).
    From calculating ... I should be traveling either 144 inches per minutes at 12,000 RPM or 25 IPM at 3600 RPM? Assuming the chip load goal is about .006. Sorry, just confused. I NEVER tried cutting pockets in wood that slow of RPM and can't imagine it working, then again, I'm a newb.
    Jan 2013
    306
    Sorry did not read post correctly.
    The SFM for wood is generally pretty high so 3600 rpm is going to be a slow SFM unless it is a large cutter.
    Aug 2013
    28
    Oh, duh. Yeah, the bit is 0.25" I double checked and I have the spindle at 12,000 RPM with feedrate at (SFM) at 25 in/min. Too slow?
    Jan 2013
    306
    If your machine can handle it yes crank up the feed. I run 60-100 ipm and 16,000 rpm.
  1. Linear rails, am I way off in my load calculation?
    By TiagoSantos in forum Linear and Rotary Motion
    Last Post: 08-22-2012, 11:28 PM
  2. Chip load/feed per tooth calculation
    By TravisR100 in forum Haas Mills
    Last Post: 07-21-2010, 07:32 PM
  3. Need help with load calculation
    By SatanKlawz in forum DIY CNC Router Table Machines
    Last Post: 01-26-2010, 04:06 AM
  4. Load calculation
    By Nigel Thomas in forum Mechanical Calculations/Engineering Design
    Last Post: 11-04-2009, 04:24 PM
