586,089 active members*
3,819 visitors online*
Page 1 of 2 12
Results 1 to 20 of 31
    Mar 2013
    66
    Garage size home made plasma table build.
    Great forum! My first post....
    Hello all, I have started my home made 2x4 CNC Plasma table project. I have been reading the heck out of all the builds here and elsewhere. For my table I went with Weldtutor style X and Y supports, but I used 2" tube for rails on X and 1" tubes on Y. Used eighth inch wall tubing, checked for trueness before cutting.
    I used 2x4x1/8 for table frame, and as main support for Gantry.
    I am using doubled up skate bearings from VBX, and for control I purchased Probotix 400"/400"/280" steppers, 10 amp 40vdc power supply, and their PBX-2RF breakout, and unipolar steppers.
    I am planning on belt driven X and Y axis, and ball thread Z.
    I will post a few pics, I have frame done, ang gantry rolling smooth. Need to start on X rails next.
    Any comments suggestions welcome... Ohhh little bio on me...
    Ex Navy Welder, ex fitter, programmer, pc builder, now own a DDC building automation business, so fab and electronics are in my blood.
    I will say I like to engineer on the fly, I envision what end result will be, and design on the go. I will draw it out on paper, but cad it as an as-built.
    Will upload pics ASAP
    Mar 2013
    66
    Well I am using Forum Runner, on an iPhone and cannot get photos to upload. Error says redirected too many times. Anyone know what causes that error?
    Mar 2013
    66
    Having trouble uploading pics from iPhone, any suggestions? Using Forum Runner app
    Mar 2013
    66
    PicsClick image for larger version.
    Mar 2013
    66
    More picsClick image for larger version.
ID:	179619Click image for larger version.
ID:	179620Click image for larger version.
ID:	179621Click image for larger version.
    Mar 2013
    66
ID:	179623Click image for larger version.
ID:	179624Click image for larger version.
ID:	179625Click image for larger version.
ID:	179626Click image for larger version.
    Mar 2013
    66
    Question for all, now is my chance to lighten the gantry, what are the benefits other than motor size? Remember my gantry is only 34" wide, weighs approx 40 lbs without rails, and z axis and two motors. Will less weight result in smoother reverse directions?
    Mar 2013
    66
    ElectronicsClick image for larger version.
    Mar 2013
    66
    Another picClick image for larger version.
ID:	179921Click image for larger version.
    Mar 2013
    66
    I ended up installing a second motor on +X axis to prevent slight wobble on direction change.
    Water tray being built tomorrow, and slats. About 2 k invested total. Painted with truck bed liner
    Mar 2013
    66
    First cut
    Mar 2013
    66
    Mar 2013
    66
ID:	181872Click image for larger version.
    Some pics of water pan, and torch mount.
    Mar 2013
    66
ID:	181874Click image for larger version.
    Before cleanup
    Mar 2013
    66
    Cutting this tonight!!
    Jun 2004
    6618
    That is a nice build. I do want to add a couple small water tables to mine as well. I have been using it a couple weeks now and it is as everyone said, messy as hell. Even though mine is in an open ended carport, the black and white soot just drifts everywhere. Water will help with that a lot.
    I notice that you and I both have the same Z axis. Those are very nice well made items. Easy to install as well. Another thing you did that I want to do is install a shield for the torch handle. That should be easy enough to do.
    Keep up the thread and show us what you are doing with it.
    Lee
    Mar 2013
    66
    Thanks, the heat shield for torch is actually a support to help keep it level, but the side benefit is what you said, a shield against water & heat!
    It takes a while to get use to using MACH3, but starting to get the hang of it. Most of my cuts will be letters, so I have to learn how to do all that weld & trim stuff with fonts so I can "stencil" them.
    Jun 2004
    6618
    Lettering can certainly be a challenge. CAD handles letters and fonts much differently than typical Graphics programs. I think I would stick with Corel Draw for doing that, rather than CAD. I do use CAD for my lettering on parts though. Just a simple block line letter font. One pass on a V bit and done. Not very elaborate, but easy and effective. That font is called GDT.SHX. I have to explode it and that makes it polylines rather than text.
    What do you use to draw in?
    Lee
    Mar 2013
    66
    Use A9cad. Also Visio
    Mar 2013
    66
ID:	181926Click image for larger version.
Page 1 of 2 12
  1. Plasma Cart Made with CNC Plasma Table
    By Tensaiteki in forum Waterjet General Topics
    Last Post: 03-03-2012, 05:15 AM
  2. Home made table, with linear rails & ball screws
    By nateman_doo in forum Benchtop Machines
    Last Post: 05-09-2011, 04:37 AM
  3. Need Advice on Finding Work Plus What Size Plasma Table to Build
    By Beefy in forum Australia, New Zealand Club House
    Last Post: 02-09-2010, 08:28 AM
  4. My first home made router table
    By mldpsu in forum DIY CNC Router Table Machines
    Last Post: 08-04-2008, 07:27 PM
  5. Home made CNC Plasma table help
    By Mick40 in forum Waterjet General Topics
    Last Post: 10-15-2007, 01:56 AM
