Bad voodoo here!!! Most bench grinding wheels are not designed for such side loads. It would be very easy to explode a wheel doing that.
Well cutting aluminum tubing isn't something I do often, however have you considered looking at this issue like a plumber would? Plumbers regularly use a rotary hand tool to cut copper pipe. Here is an example of a powered unit:
M12TM Cordless Lithium-Ion Copper Tubing Cutter Kit | Milwaukee Tool. Manual examples are here:
Pipe Cutters - RIDGID Professional Tools and here:
Tubing Cutters - RIDGID Professional Tools. Tubing cutters leave an internal burr thus requiring a reamer but the cut is otherwise clean and square. Once you learn to use the tools you will not even think about trying to cut said tubing with an angle grinder or hack saw. Tubing cutters are fast and safe compared to most other solutions, accurate too.
Better yet a manual tubing cutter doesn't even require a battery. They can be cheap but I'd warn against going to low end. Even so they are far cheaper than an angle grinder and the supplies for them. More importantly you can buy spare blades for as little as $3.00. Now I'm not going to say that a tubing cutter will solve all of your cutting needs but they are simple and safe for use on tubing.
You may also want to consider tools for the drill to help with tube end prep. Reamers and piloted mills might be useful for cleaning up tube ends. You might run out of torque with 12 volt tools driving such cutters in 1" tube.
In any event I don't see a angle grinder as the right tool for cutting tubing at all, there are simply safer approaches. A Sawsall or bandsaw come to mind if a tubing cutter won't work.
Even after all of the above considerations you will likely still find a need to sand or grind stuff. The problem with angle grinders is coming up with a workable stand. This makes me wonder if an automobile will be near by. One possibility would be to buy a small 12 VDC Motor and to attach a 5" disk to it effectively making a small disk grinder/sander. You might need a friend with a shop to pull this off. The idea would be to run the unit off of a car battery. This assumes that you can make a safe system mechanically and electrically though. Of course you could do this with a battery powered angle grinder, the problem here would be rigidly mounting the grinder to the stand and the probably shorter life span of the grinder used that way. Plus a car battery in a home built grinder adds a lot of ballast to the stand. There is nothing worst than a grinder that walks around on you. I know this whole paragraph goes against your light doctrine but you will need to address stability some how. Consider the possibility of local ballast in a grinder stand, that is design the stand to hold rocks or sand found locally.
In any event take the above with a grain of salt. I still don't know what you are doing nor how focused you are on work with tubing. One thing for sure is to concentrate on safety. Create a tool crib that let's you accomplish things the safest way possible.
