586,096 active members*
3,790 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > daisychaining 2 (or more) ATX computer PSU
Page 3 of 3 123
Results 41 to 52 of 52
  1. #41
    Dec 2005
    3319
    Yes, reread post 39 about grounds as this is the only fly in the ointment.
    You can minimize problems by feeding them off of the same power strip and keep all them on/of the same high side polarity.
    If the P/S's are not IDENTICAL models, that could pose a problem/issue.
  2. #42
    Oct 2005
    1237
    I'm modifying a server redundant power supply. Each individual power supply is the most robust I've ever torn apart, and each plug into a main box, not have wires coming out of them. The cases are stainless steel, but they have the same problem of using the case as a common negative for several parts of the circuit. The back circuit board they plug into ALSO has the grounds running to the case, so even though one supply was redone, I have to redo where it plugged in also.
    I'm in the process of pulling the secondary power transistors from the receptical circuit board now. After, I'll do the series wiring on that board for the two supplies Will end up with WAY more power than I need, but I need 24volts and the power supplies were free,,,,, 300w each, and all I'm doing is powering 24v. air selinoids for a Kurt draw bar and air breake on my mill. Maybe it's time to look into low voltage Halogens for lighting. :rainfro:
  3. #43
    May 2008
    37
    If I was to use 2 or even 3 PSU's would that be the right amount of power to run the driver and 3 stepper motors?
    I just wounderd with the dirergrams showing just one stepper motor on
  4. #44
    May 2008
    37
    sorry, can any one help with this question aboth /\ /\
  5. #45
    Feb 2006
    338
    You have to add up the power requirements for the 3 drivers.
    If your running 3 x 3A @ 24V you will need:
    2 12V (= 24V) power supplies in series that are rated at least 9A (= 3 x 3A for 12V) In this example you would ideally have a 3A fuse on each driver.
    For more voltage add power supplies in series, see post #13
    You amperage is limited to what the lowest 12V amperage output power supply
  6. #46
    Quote Originally Posted by NC Cams View Post
    The voltage at any succeeding 5v tap depends on what two points you measure the voltage.
    The 5v from the "bottom" P/S from where you're referencing ground is going to read 5v.
    If you measure from +5vdc on the next one up to the ground on the "Bottom" P/S, it should measure 10vdc. If you measure it to that respective P/S's ground, it should be 5vdc.
    If you have at third supply stacked, it will read 5v at its own ground but 15vdc with reaspect to the "bottom" ground referenced P/S.
    Still don't understand?
    Hook 3 batteries (9v will do nicely) in series. Then measure the voltages at the various terminals and you'll see how the voltages relate. Arbitrarily keep the ground at one point and simple move the + probe.
    You'll now understand how a -9vdc is generated from a +9v battery.
    Incorrect. The common line of PS2 is at 12V, so the 5V line on that will read at 5+12 = 18V above the ground/common line of PS1. The common line of PS3 is at 24V, so its 5V line will read at 5+12+12 = 29V. Etc.
  7. #47
    Quote Originally Posted by emtffkev View Post
    Hate to revive an old thread, but.....
    Is it possible to daisy chain 2 sets of 2 power supplies in series (24v / roughly 3A), and then daisy chain those two sets in parallel (24v / roughly 6A). These aren't ATX supplies they are ones I've scrapped from some OLD dot matrix printers and they only have a 3A output but 12v each. I have 4 of them...
    Hm. Yes, I think you can, if you use isolation diodes between the supplies. They may not be necessary, but it is a good idea. Use shottky diodes for low voltage drop.
    Otherwise if one supply loses power, the output of the supply in parallel with it may cause a fault by supplying voltage into the unpowered supply's output. Of course if that happens and your circuit is drawing more than one supply can provide, you may end up with fireworks. Like having one battery die first in a series string and reverse charging that battery.
    There is also the potential problem of slightly different output voltages causing one supply of a parallel set to coast while the other does all the work.
    I have a vaguely similar situation. I have a bunch of 28Vac 3A transformers from old Apple Imagewriter II printers, I'm going to parallel them by having separate bridge rectifiers on each secondary, going to the same bank of smoothing capacitors. I will also be putting a smallish series resistor on each, between the separate bridge rectifiers and the common capacitor bank.
    If I weren't so broke, I'd just buy a $20 transformer... 10A at 24Vac (about 36V rectified and filtered).
  8. #48
    May 2009
    Smile Use 2 ATX PSU
    Quote Originally Posted by AlienSteve View Post
    You can use 2 ATX PSU in series , but the second ATX ground must be isolated . Cut the the pcb on 2nd ATX so it's not connect to ground , then connect positive lead (12V) of 1st ATX to the negative lead 2nd ATX (12V) . Now you get 24V DC from negative lead 1st ATX PSU to positive lead 2nd ATX PSU , its become 24V DC and more than 10A output . Or use 2 ATX PSU in serie but the ATX PSU must fully insolated , do not connect each other .
  9. #49
    May 2009
    14
    Serial Connection of two power supply
    We use two S-150-24(+24Vdc, 6.5A), there are four terminals for the two
    power supply, Gnd_1,+24V_1, Gnd_2, +24V_2, then Use Gnd_1 as common
    ground, and CONNECTING +24V_1 with Gnd_2, and use +24V_2 as +48Vdc
    output.
    That will be a +48Vdc, 6.5A power supply by using two +24Vdc, 6.5A power
    supplys.
    We have used this +48Vdc,6.5A power supply to power up Dyn2 AC servo
    from www.dmm-tech.com
  10. #50
    Jun 2007
    149
    This idea is good, my friend is an electronic engineer and he said all I have to do is isolate the DC circuit from earthing to the case and make sure all the power supplies have the same amp rating.
    I'm getting 48vdc and 14amps for 3 1200oz steppers from scrap pc parts!!!!
    God bless IBM!
  11. #51
    Nov 2003
    314
    Thanks for this thread very useful.
    Is there any problems with connecting two 400w supplies together (parallel) with one output of 12.2 and the other 12.5?
  12. #52
    Nov 2003
    314
    To answer my own question now I have tried it, No!
Page 3 of 3 123
