586,035 active members*
3,751 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Integrator Parameter File could not be read from disk.
Results 1 to 7 of 7
    Aug 2010
    When I power up my machine I can not get it to calibrate and I am geting this alarm. "Integrator Parameter File Could Not Be Read From Disk. The File Allocation Table Is Corrupt.
    Feb 2012
    67
    Did you leave the floppy in the A: drive when booting up? I think I've seen a similar error when I've done that.
    Aug 2010
    Nope no disk left in. I can get to the main screen and move in manual. Also I can review the program. But I can't get the machine to calibrate or run a program.
    Jun 2008
    1104
    Sounds like your Configuration has got corrupted. Do you have a backup disk?
    Aug 2010
    Yes I have a book of disk. Not sure which one to use. Or how to use it exactly.
    Jun 2008
    1104
    If you have the control started, get a new floppy disk and make sure it's formatted.
    Put it in the machine drive and select Auxiliary followed by system configuration. Next select backup config.
    Wait until the machine has finished doing the backup. This is just so you have a copy of how the machine is now.
    Find the machine config disk in your folder.
    Put this in your drive and go through Auxiliary and system configuration but this time select restore config.
    Once it has finished loading the files, reboot the control.
    Be sure to check and reset all tools in the toolchanger map if it has one as they may not match the tool positions in the magazine.
    Aug 2009
    Re: Integrator Parameter File could not be read from disk.
    I have same issue and unfortunately without backup disk on my hand. I even got error 'The File Allocation Table Is Corrupt' when I tried to backup current config files. Is that possible to get factory config disk, any idea? Thanks a lot.
  1. Read D-parameter in CNC-programme
    By Ingmar Trobäck in forum Fanuc
    Last Post: 07-26-2012, 01:18 PM
  2. Free CNC DXF file art disk download
    By custom dxf file in forum News Announcements
    Last Post: 01-25-2011, 06:07 PM
  3. can we read the current status of a parameter
    By sinha_nsit in forum Fanuc
    Last Post: 12-07-2009, 01:44 PM
  4. Halloween DXF file Art Disk download
    Last Post: 09-09-2009, 05:07 PM
  5. File Upload from Disk
    By Big"E" in forum Haas Mills
    Last Post: 06-16-2007, 02:35 PM
