3TC Parameters ????
Howdy!
A couple years ago this lathe stopped working properly. When you run a program it would stop at an M8. I found that if I switched the coolant on then back to auto it would function normally. If the switch is in Off position the program will run normally....with the coolant off not cool
I switched lots of little relays thinking the problem would follow the relay...no luck.
Question Is there a parameter in the Fanuc which could have been changed which looks for feedback from the coolant system...my point being that the machine may not have that sensor and did not use that parameter when it was new? The maint. manual is no help here.
Thanks tons!
i build the braces that keep american teeth straight......tick tick tick
