I have a CM101 breakout board and I need to know how to wire a 24V pneumatic solenoid to it.
How to connect a 24V pneumatic solenoid to CNC breakout board.
If the BOB has outputs, e.g. relay contact then if the contacts are rated ok then you can switch the 24v+ direct, you need to wire a reverse biased (BEMF) diode across the coil.
http://www.progeny.co.uk/Back-EMF-Suppression.aspx
Al.
Albert E.
the CM101 has a relay that is rated 24V
so does that mean it can connect directly to the board?
does the diode need to be facing certain way? and is there a specific diode to use.
Thank you so much for your time
I will pay it forward once I get the hang of this
Sincerely
Anna
Diode can be any of the 1n400x series, 1n4007 has a wide range.
The stripe has to face the +v side of the coil supply.
take the -ve direct to the solenoid, 24v+ to one side of the relay contact, the other contact to the solenoid.
It is preferable to wire the diode as close to the solenoid as possible.
Al.
Albert E.
Thank you very much!! I have been looking for wiring diagrams and such without any luck. I will give this a go and post a wiring diagram if I get lucky.
Best regards
Anna
