586,121 active members*
3,523 visitors online*
    Mar 2013
    Mazak 630-5X Pallet changer fault
    We have a Mazak 630-5X which was interrupted during a pallet change operation then powered down without resolving the hang up. Now the machine has been manually returned to it's home positions and all parts of the pallet change process returned to their resting state but now the machine won't allow any operation as i am led to believe, that these controls have latching circuits that remember what the machine was doing when it faulted and wants to complete this procedure. Is there any way of clearing this from the controls memory?
    Any feedback would be greatly appreciated.
    Jan 2011
    350
    Very likely that you have a data address on you plc that changes when you make your pallet change, so likely just a bit to change from 0 to 1 or 1 to 0, you got to look it up on your manual (it should also be obvious on your ladder, if you know how to read it).
    Cheers.
    Mar 2005
    988
    No alarms? or messages?
    Also, double check your APC maintenance pages to be sure all the correct positions are lit for the changer .... (otherwise, may have to do what the person above mentions)
    It's just a part..... cutter still goes round and round....
    Dec 2007
    36
    We have an H630 with a 6X pallet changer. I am familiar with what you are describing. If the pallet change cycle doesn't complete, the machine will not automatically pallet change on and off the setup station. The only way I have found to correct this is to physically put the machine back into the condition that it was in when the error occurred, and finish the cycle manually. The pallet changer can be operated in manual. I hope this answers your question. As far as the ladder goes, I am unfamiliar with this side of the control.
  1. Pallet changer
    By JackDeRam1 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-26-2012, 08:13 PM
  2. vf3 ss pallet changer
    By mayhem in forum Haas Mills
    Last Post: 04-25-2011, 10:45 PM
  3. Pallet Changer
    By MIDDEN300 in forum CNC Machining Centers
    Last Post: 09-20-2008, 02:32 PM
  4. urgent:parameters for pallet changer ( mazak ajv 3560)
    By Denis13 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-12-2007, 06:38 AM
  5. VF-3 & Pallet Changer
    By big_mak in forum Haas Mills
    Last Post: 10-12-2007, 08:00 PM
