I was cutting a small part from plastic that requires a cut that is a dead end on one side of the part. No problem until laser cut makes it the last cut AFTER cutting all outside paths and the part falls out. Go to manual and on pg30 it states that you go to a icon(looks like a sat dish) and that clicking in it, the mouse pointer will change to a crisscross--now the problem, it does not! It changes from a white mouse pointer to an all black one. As the manual states--move the pointer over the graphics, click on any point and this will be the new starting point, BUT all it does for me is change the line I click on to RED, as if you are normally going to edit it. I tried all the settings that would seem to be possible to correct it but no go.
Any ideas anyone?
Rick
