586,608 active members*
3,763 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Choosing servos and drivers
Results 1 to 5 of 5
    Sep 2010
    528
    I am helping a friend convert a Warthog 4'x8' CNC router from steppers to servos. We have been told that with the existing gear reduction we need 800W servos.
    We are using WinCNC as the controller, and need a servo driver that handles the error correction in the driver.
    Any ideas?
    If you need more info about the machine just ask.
    Thanks,
    James
    James Harvey
    Harvey Development Corp.
    www.Harvey-Development.com
    36" x 52" CNC Router
    ULS-25E 12" x 24" Laser Engraver
    Sep 2010
    1765
    wow! sounds overkill. since u r hlping him, why not help him right size the new motors by using a motor sizing program for him, rathr than relying on someone elses guess? for instance:
    MOTIONEERING® | Kollmorgen
    no guessing involved!
    Sep 2010
    528
    Quote Originally Posted by mike_Kilroy View Post
    We were told by the manufacturer that 800W servos would be the right sized motor with our current gear reduction, so it's not really guesswork.
    Can you suggest a servo/driver combination?
    James Harvey
    Sep 2010
    1765
    Quote Originally Posted by jharvey407 View Post
    nope. no info to decide from. too much 'guesswork' remains. for instance....
    what is part no of present motors(s)? how many? x,y,& & rotary table? tilt axes? what size is(are) present motor? shaft dia? length? mounting BC? pilot dia? any length issues? diam issues for replacement? what is part no of present driver? what is supply voltage? current? how to control? step/dir? analog input? 0-5v? +/-10v? any size issues in cabinet for replacement drives? need premade motor cables? how long? any flex?
    someone should go thru motor sizing program such as I suggested, for each axis, to determine application info like what is top speed required? torque required? reflected inertia of the load? supplying replacement motors & drives without all this info would be crazy.
    I can supply you 800watt motors that have inertia so much lower than your machines you would never be able to tune them, or so high you would never be able to accelerate them in time wanted (which is what?). I can provide you an 800 watt motor rated 800watts at 12,000rpm so its torque will be so low it will not move the slides. Or I can supply you an 800watt motor with so much torque it would move your friend's shop down the street, but you probably would not be happy with the 0.25IPM max traverse speed capability....
    Once all this is nailed down, then I would be very happy to provide some options from our bag of tricks as I am sure others would!
    Sep 2010
    528
    Thanks, but the local Yaskawa rep came by and sorted things out for us.
    James Harvey
  1. Choosing PS and drivers - Recommendations?
    By Jkountz in forum Stepper Motors / Drives
    Last Post: 01-15-2012, 08:04 PM
  2. Servos, drivers, break out boards
    By HereinCS in forum Servo Motors / Drives
    Last Post: 08-13-2010, 06:09 PM
  3. Help Choosing B.O.B. and Drivers
    By Jesse B in forum Open Source Controller Boards
    Last Post: 12-05-2009, 06:53 PM
  4. Help choosing steppers and drivers
    By Aaronem in forum DIY CNC Router Table Machines
    Last Post: 03-10-2008, 03:06 AM
  5. need drivers for servos
    By visky in forum Servo Motors / Drives
    Last Post: 01-21-2007, 02:36 AM
