586,067 active members*
5,380 visitors online*
IndustryArena Forum > CAM Software > CamWorks > multiple work coordinates
    May 2007
    15
    Hi
    I have a part that i want to machine on both sides,g54 &g54.I will be using the same tooling for both sides.Right now I can only get it to post all g54
    toolpath and the all g55 toolpath.How do I it to do g54 & g55 toolpath with each tool before changing tools?
    Mar 2008
    638
    Sort operations across setups. Right click on the NC manager and choose "sort operations" and then "By and Across Setups". You'll have to drag some operations around to get it totally the way you want it.
    Or you can do it manually by Spliting each set up and dragging operations.
  1. Yasnac MX2 work coordinates.
    By PHD in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-15-2021, 09:21 PM
  2. Work Planes / Work Coordinates
    By MICFDI in forum Esprit
    Last Post: 10-04-2014, 02:41 PM
  3. setting work coordinates through program
    By lsrengineering in forum Haas Mills
    Last Post: 06-08-2010, 03:07 PM
  4. G154 Select Work Coordinates Help
    By chucker in forum Haas Mills
    Last Post: 12-13-2008, 09:39 AM
  5. Okuma Work Coordinates
    By firedog in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-10-2005, 12:43 AM
