Model: SK-1325WAT3(Independent Z Axis, Auto tool change with 3 Spindles. )
http://www.signkey.com.cn/en/display.asp?id=71
Standard Features
The lathe is founded by industrial pipe welding, box-type structure to ensure the high stability
The Special instruments to eliminate welding stress, high-precision machining planer ensures the precision and no deformation.
The major machine body makes the stability and no shacking in high speed.
XYZ all apply imported screw,high precision gear frame and linear guide ,ensuren the high accuracy .
The professional mechanical design,scientific structure and generous appearance.
Intelligent and humanized design . Can Reduce the trouble of change tools ,,It is more effective to improve the efficiency of processing.
Applications :
Widely used in Antique furniture with relief carving,wood carving,furniture processing,insturment making ,
3D light box making , Aluminum composite panel ,funding mould decorative doors and windows processing.
Special configuration : It can be customized servo driver , large format and special format models and choose imported spindle .etc...
Technical Parameter
Model SK-1325WAT3
Table size: 1540×2640mm
Working size: 1300×2500×130mm
Spindle Voltage: No.1 Spindle-5.5KW(Air cooling ); No2,3 Spindle-3.7KW(Air cooling)
Z Structure: Independent Z Axis,3 steam cylinder, high Accuracy ball screw precision
Spindle speed: 6000~24000rpm
Driver: Stepper Driver(it can choose domestic or import servo driver)
Tool Diameter: ∮3.175,∮4,∮6, ∮12.7mm
Structure Cast: Square Tube
Transmission: High Accuracy Gear Rack
XYZ Guiding Rails : Linear Square rails
Reposition Accuracy: <0.03/300mm
Engraving speed: 12000mm/min
Date Interface: PC Connects directly
Format of Instructions: G code Format or HPGL
Voltage: AC220V/50-60Hz or 3 Phase AC220V/50Hz or 380V/50Hz
Net Weight: 1200kg
Note: No further notification is performed when the parameters and models are changed. For latest information, please contact www.signkey.cn
