I have Rhino 5 64bit installed on two machines ... one upstairs in the office and one in the workshop. I have a single license that is managed via Zoo. This ensures that I can only have one Rhino running at any given time. This reasonable and rational licensing works out quite nicely for my hobbyist needs.
If I buy MadCAM how will the licensing work? Can I install it on both machines and everything will continue to work as nicely as it has ... i.e. I can only use one Rhino 5\MadCAM instance at a time and which of the two machines I use is not an issue ...
... or will there be some draconian licensing issue that will require that I only install it on one of the machines and essentially neuter the Rhino 5 very user friendly floating license concept
... or be I be required to buy two licenses even thought it will be impossible for me to use them both at the same time as Zoo prevents Rhino from running on both machines at one time.
Arvid
