I have a Bridgeport Series II R2E3 Boss 8 mill which I have been cutting a large 7075 Aluminum mold. The mold has a lot of contours, and I have using cutters from 2" down to 0.04".
Everything looks beautiful on the first two plates. While completing the roughing of the last plate, the machine quit gave an axis limit notice, and would not retract the quill. I turned the machine off, and because the cutter was down in the mold cavity, I retracted the Z by removing the cover and turning the belt. The belt was very hard to turn. It did get easier, and I turned the machine on. Everything seemed to be working, except there was now about 0.010 backlash in the Z which was never there before.
I should note that I had just done a lot of roughing with a 2" cutter that chattered on plunge. (100 LBS of metal removal). Right before the machine quit I had been having to use air to clear the chips out of the cavity as it cut, and chips were flying everywhere. A chip could have got into the head.
Due to ceiling height restrictions, I am unable to remove the head of the machine, but I lifted it enough to be able to flush off the ball screw with solvent. I also replaced the lube metering units in the head. Everything now moves easily up and down, so I adjusted the belt tension and put it all back together.
There is still about .008 of backlash in Z.
Is the ball screw damaged? It happened too fast to be wear.
Could the pulley be loose on the ball screw?
Any help would be appreciated. I need to finish this mold!
