does anybody know if you can write labels in Edgecam if so where do you write them and call them up?
Please explain what are "Labels".
in heidenhain programming labels are like sub-routines
Should be easy enough. Make sure you've selected a tnc post, try a new adaptive tnc template if you're not sure.
Then when you select a cycle which gives you the option to select subroutines it should output with lbl's.
Done loads in my time.
