586,655 active members*
2,854 visitors online*
IndustryArena Forum > CAM Software > Mastercam > separate jobs into one job
    greenene Guest
    As part of a project with MC, I've accumulated a dozen files, all of which use the same stock material--in wood-- and cut various parts.
    Now I'd like to cut all of these parts on one larger piece, and am wondering what is the easiest, least problematic way to cut and paste or import all the separate files into one file so that I can cut on one large board. Tools are the same and stock is the same, just a simple operation of nesting them into one board and then cutting away. I am thinking that the operations import/export is the way to go, but I am curious to hear from others who think they good have short cuts.
    tc
    Dec 2008
    717
    Importing the operations WITH geometry on each of them will work...but you may need to mess with the origins or where they are at to get them where you need to be for one piece of stock (or just use a separate origin for each part). You may want to put each piece on a separate level so you can move it easily to the correct location so they aren't overlapping or wasting material. How many operations are we talking about?
    How about just writing a simple program with subs for each part and origins for each one where they should be on this material? If you have it drawn nested in the new material already then finding each parts new origin would be simple.
    Tim
    Apr 2003
    3578
    What version are you using and are you using Router product or Mill Product.
    There is a tool call nesting for this.
    Cadcam
  1. Separate GCode
    By pinguS in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-07-2010, 06:16 PM
  2. Jobs!! Jobs!! Springville NY Jobs!! Jobs!! Jobs!! Jobs!!
    By HBP in forum Employment Opportunity
    Last Post: 11-15-2007, 04:41 PM
  3. separate employment from RFQ'S
    By ddprecision in forum Employment Opportunity
    Last Post: 12-21-2006, 06:53 PM
