586,121 active members*
3,721 visitors online*
    Dec 2006
    6
    828 tool change
    I have an 828 control on a 5 axis. Does anyone know how to precall a tool so that if the operator pushes cycle stop while the magazine is indexing it wont alarm out and need the mag referenced. All the fanucs dont have this problem. you can press feed hold while the tool that is precalled is coming around and it stops machine motion but not the magazine. It stops when it arrives at the precalled tool. Is there a production mode or something i am not aware of?
    Aug 2006
    98
    This procedure is made by the PLC !!! If the creator don´t think about that and don´t write in the plc program, you will have this problem all life !!!!!
    Dec 2010
    50
    If it is an 828D then you don't have a full 5 axis machine that supports simutaneous 5 axis machining. You would be able to do 3+2 5 axis control. The previous post is fairly accurate in that this function is likely how the builder designed the PLC logic. Who is the machine tool builder? Model #?
  1. How to change Tool change position(About MAZATROL T1 control)
    By liushuixingyun in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-07-2014, 01:33 AM
  2. Bridgeport interact 412 tool changer does not slow b4 tool change
    By RMARCH in forum Bridgeport / Hardinge Mills
    Last Post: 11-12-2013, 10:50 PM
  3. Replies: 4
    Last Post: 02-01-2011, 03:10 PM
  4. Replies: 0
    Last Post: 02-14-2010, 07:26 PM
