586,106 active members*
3,301 visitors online*
Thread: wood gears
Results 1 to 8 of 8
    May 2012
    33
    wood gears
    Good Evening. I am trying to import a dxf of some wood gears. Only problem I have is all the teeth are broken. Is there an easier way besides joining lines around a 60 tooth gear? Im guessing when gears were drawn they had a brake and when copied around it duplicated the break. I am using V25 standard. Thanks in advance.
    Ronnie
    Apr 2009
    3376
    Fix one complete tooth and root,trash can the rest.Rotate/copy 59 times with 6 degrees rotation on the Z axis
    Aug 2012
    621
    You could try doing a section and mirroring, but you'd have to be pretty careful to get the segments just right. Jrmach's method is probably better.
    Luke
    "All I'm trying to find out is the fellow's name on first base" -- Lou Costello
    May 2012
    33
    Thanks for the replies. I will dive into the software and see if I can figure it out. I'm still a newbie with bobcad.
    Ronnie
    Dec 2008
    4548
    Apr 2009
    3376
    Burr,,the first works fine,,the 2nd and 3rd will not play????????????
    Dec 2008
    4548
    Dec 2008
    4548
    Quote Originally Posted by jrmach View Post
    Fixed that...
  1. Replies: 0
    Last Post: 07-21-2012, 03:14 AM
  2. Cutting wood gears for clock
    By bananafish in forum WoodWorking Topics
    Last Post: 11-29-2011, 12:37 AM
