I've tried moving the X-axis all the way to the pos side (without hitting the limit) and the door still wont close and throws the code. Also, when I press teh 'Home 1' or 'Home 2' buttons the spindle head doesnt move to its home positions. It just sits there with the home key I jsut pressed lit.
When you first power up, press Home 1 key. Now press the axis keys to home it out (X, Y, Z). Use negative direction first. If you're close to machine home, the machine will reverse to the positive direction on its own. If you're far away, then after you press the negative direction, switch to the positive direction. When all axis are home, the red LEDs will light up on the control panel for each axis.
Now press the "machine" key (you must be in Manual mode) and go into the ATC page and press the "ATC door close" button.
It's just a part..... cutter still goes round and round....
