586,075 active members*
4,127 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Old VF-1. Need to replace spindle
    Nov 2004
    83
    Somebody give me a walk-thru on replacing the spindle cartridge in a Haas. I've replaced the draw-bar a couple times but the bearings and Cat40 taper are GONE in this rig.
    It's an early 90's VF-1 machine with a 7000 rpm spindle.
    JohnF
    Bogart Racing Wheels
    Phoenix, Az.
    john@
    Jan 2012
    59
    seen it done many times looks pretty simple.
    take the bolts out of the bottom cartridge comes out the bottom
    be sure to replace lovejoy bushing also
    on a direct drive spindle you have to loosen motor and realign it with the spindle (cheap mill)
    not sure about one with a gear box
    Mar 2010
    1852
    You will need to tram the spindle in after mounting. Use small brass shims at one or more of the 4 mounting bolts.
    Mike
  1. need to replace spindle encoder
    By samu in forum Fanuc
    Last Post: 02-28-2013, 06:16 PM
  2. Replace spindle drive
    By Asfar in forum Servo Motors / Drives
    Last Post: 05-12-2012, 01:33 AM
  3. procedure to replace spindle belts?
    By coop31 in forum Cincinnati CNC
    Last Post: 12-30-2011, 05:12 PM
  4. Replace spindle or?
    By gorby in forum Haas Mills
    Last Post: 12-19-2009, 03:52 AM
  5. In need of a spindle to replace PC892
    By spoiledbrat in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 10-10-2007, 08:44 PM
