586,072 active members*
4,369 visitors online*
    Mar 2013
    15
    Haas HL2 turret unlock
    Good Morning Guys
    I have a 1998 Haas HL2 I recently purchased, and I keep getting a turret unlock F, fault code, Are the sensors hard wire ON/OFF switches so I can see if i have a bad switch or something else wrong?
    Jul 2005
    12177
    On a machine that age they are microswitches; it is possible you have a switch hanging up. It is years since I had the covers off on my HL1 but I think the switche(s) you need to look at are inside and you have to remove the top plate behind the turret. Once you have the cover off you should be able to operate the switch by hand. On the diagnostics page somewhere I think you will find an entry for turret lock/unlock which should change between 1 and 0 when the switch is operated.
    Feb 2010
    1184
    Quote Originally Posted by Geof View Post
    What he said!
  1. Entering every Haas unlock code
    By b1kmpn95 in forum Haas Mills
    Last Post: 04-03-2021, 04:02 AM
  2. Haas SL-40 turret
    By Rojas in forum Haas Lathes
    Last Post: 08-24-2012, 03:39 AM
  3. Haas ST-20 turret
    By chengkung in forum Community Club House
    Last Post: 09-21-2011, 03:04 PM
  4. HAAS SL-20 TURRET PROBLEM HELP
    By allmotormatt in forum Haas Lathes
    Last Post: 01-20-2011, 06:47 AM
  5. Haas SL-20 Turret Not Clamping Quick Enough
    By ncprecision in forum DNC Problems and Solutions
    Last Post: 12-15-2007, 02:46 AM
