I decided to use a Makita Die Grinder
When i designed my router, I decided to use a Makita Die Grinder #906H, 30,000 RPM dual bearing spindle, easy to repair, made from solit cast aluminum, not plastic! But most of all is was very slender, at 2.8" diameter!
I took the spindle nose casting off and used my lathe to turn it round, to make it easier to clamp on to!
The spindle has a maximum of 1/4" dimeter collet, but I made a reducer for 3/16" and 1/8" shank endmills and bits!
Dremel's are really nice, and not as noisy as my die grinder, but the ergonomic handle designs are impossible to clamp on to!
In my opinion!
Eric
www.widgitmaster.com
It's not what you take away, it's what you are left with that counts!
