586,106 active members*
3,106 visitors online*
Page 19 of 24 91718192021
Results 361 to 380 of 472
  1. #361
    Feb 2010
    Hello everyone, I have been reading this thread for quite some time... and just now decided to become a member. I work in mechanical design and I will volunteer to do some 3d modeling if anyone needs. I use autodesk inventor and can maybe do some file conversions as well.
    I have seen a lot of nice work from a lot of you, and I was wondering if anyone could provide any finalized g code? I would like to try making one of these if I ever find a friend with a CNC
  2. #362
    Apr 2009
    144
    Hey all, interesting thread! Anyone have any updates?
    I am just in the final stages of my DIY JGRO router build, and I really want to try building a strat. I have never even had a solid body guitar (only acoustics), so this will be a steep learning curve for me.
    I actually bought the body design and machining DVDs from CNCguitar.com and found them extremely enlightening.
    I have downloaded the body and neck files, but I have a few questions for you guys...
    Why can't the edge radius be done on the cnc router, rather than on a conventional router?
    What is the easiest way to drill the holes from the Jack to the control cavity and from the trem. back cavity to the control cavity?
    Why not have the CNC drill the tuner peg holes and radius the "fretboard"
    Best way to drill the truss rod hole in the end of the neck? Anyone successfully make a jig for that?
    JGRO Complete - G540, 380oz Nema23s, 1/2-10 ACME, 30"x14", Craftsman router
    Joes 4x4 R&P in progress
  3. #363
    Apr 2009
    144
    Oh, and about those files, maybe someone could clear up my confusion...
    I don't think I'm scaling the neck right as the with at the base where it fits the body comes out to 2.1952...?
    Any specific reason for that? The stewmac replacement necks are 2 3/16" and the body that turmite posted has a neck pocket of 2 1/8"
    I don't see where gregmary posted his body? Did he route a 2.2" neck pocket in his?
  4. #364
    May 2006
    803
    Strat thread revival
    I am getting ready to go
    Tooling picture.
    Been doing this too long
  5. #365
    Mar 2006
    489
    Did gregmary ever finish his Strat? I've just finished reading this entire thread, but didn't see and final pics.
    Bostosh, I've stared at your pic for a few minutes. I'm assuming that's your tooling plate? If so, are you making a separate one for each side of the body? I also don't really understand the purpose of a tooling plate for this type of build unless you plan on making hundreds.
    I'm currently modeling a tele in SW2010 and plan to start on it soon. I'll probably start a new thread for that build though...
    Paul
  6. #366
    Oct 2009
    14
    Strat Neck Original Fender Drawing
    I am currently modelling this in Solidworks, will post when finished.
  7. #367
    Mar 2006
    489
    I found that little gem about a week ago and used it to model the tele neck. :cheers:
    Paul
  8. #368
    May 2006
    803
    Fatal,
    This is a tooling plan which I can rip material out with 15-20 Hp and 1" cutters full depth.
    Or go high-speed-feed programming style.
    And have enough clamping places for most any shapes.
    Its hard to put a clamp on when the material is flying away.
    (universal tooling plate) (table slots for different machines)
    actually I am do things the way I did parts in Aerospace-land.
    And just exercise the software too.
  9. #369
    Apr 2010
    Hello peoples, does anyone have a DWG or DXF 3d file of a strat neck? I've got the body but haven't the neck. Any help would be greatly appreciated.
  10. #370
    Dec 2011
    Sorry I'm so late to the party. But here is a complete model you would need to make everything yourself basicly grabcad.com/library/62-strat-asm
  11. #371
    Quote Originally Posted by protomachinst6 View Post
    Looks great, but how do you use this type file? I have Rhino, and 2 CAD programs and SolidWorks viewer, and none recognized this file type.
    Lynn
  12. #372
    Dec 2011
    let me know what file type you need and i will gladly convert and post them for you
  13. #373
    Thank you for the generous offer. Can you perhaps convert to an .STL file?
    Lynn
  14. #374
    Dec 2011
    I sure can give me an hour and I'll have the files posted here
  15. #375
    Dec 2011
    i tried to use common formats, if you need anything else just shoot me a message i hope this helps get everyone going again
    Spencer
    Attached Files Attached Files
  16. #376
    Spencer
    Thank you Spencer. I'd like to try to cut this some day. I own a couple MIM Strats and wouldn't it be a hoot to build my own!
    Lynn
  17. #377
    Dec 2011
    I Also plan on building my own body and neck, prob. In the next several weeks I would like to be able to start machining.
  18. #378
    Ditto!
    I have gathered almost all the materials I need to build a 2x3 gantry router. I have everything but the electronics. I will get them when I decide on a package.
    How would you actually start machining something like this? I assume you would use a program to break the model down into it's parts that you could machine. I currently have Cut3D; I wonder if that could do it (I don't think it will break up the model though)? I can see now I'll need to start with foam blanks while I'm learning how to cut guitar parts; too expensive to learn with wood!
    Lynn
  19. #379
    Dec 2011
    I personally will be using mastercam V9 to make tool paths for a machine at worked, basically it comes down to how to hold it and in what order to machine it in. I plan on doing the front first putting in all the holes and running an initial rough and finish surface contour to get the shape then flip it over. I'll end up adding more holes to pick up location and a traming hole as well
  20. #380
    May 2006
    803
    Lynn,
    1st question is how do you hold the material you wish to cut to the machine?
  1. Strat .dxf files
    By chickenhawke in forum Musical Instrument Design and Construction
    Last Post: 02-13-2016, 09:40 AM
  2. Strat/Jem Blueprints...
    By CyborgCNC in forum Musical Instrument Design and Construction
    Last Post: 09-16-2009, 09:11 PM
  3. carved top strat
    By justin22885 in forum Musical Instrument Design and Construction
    Last Post: 06-18-2009, 12:27 AM
  4. Rendering a Strat....came out good
    Last Post: 04-13-2009, 02:44 AM
