586,089 active members*
3,893 visitors online*
Thread: New
    Jan 2013
    Question New
    Hello my nane is Heyward and I wanted to know, I am starting school for the cnc field and which machine is use more lathe, mills, or swiss machine's
    Jan 2012
    59
    crawl before you run start with lathes the simplest. You want to be a swiss or a mill turn programmer some day
    Jan 2013
    thanks for the advice because I am starting lathe's but I worked as a cnc operator using thermwood and royce machine's for plastic as a setup tech
    and I know that the machines are very different. but my Goal is to be a setup/programmer.
