586,077 active members*
3,591 visitors online*
    Jan 2011
    Through Spindle Air-Who has it
    I am looking to see if anyone has installed a through spindle air system on their NH or similar machines? How is the air pressure/volume? How long did the install take?
    Feb 2009
    6028
    Lots of years on Mori, never seen a through spindle air, just the spindle nose air that comes standard. I would assume to install such an item, the coolant through spindle coupling would need to be changed, since they require liquid volume and 225PSI to close.
  1. Mini Mill X2 Spindle Head + VFD + Chinese Spindle= custom!
    By diyengineer in forum Uncategorised MetalWorking Machines
    Last Post: 12-26-2016, 10:04 PM
  2. Replies: 5
    Last Post: 07-19-2013, 05:16 AM
  3. VistaCNC iMach 3 Spindle Tachometer causing inconsistent spindle speed
    By QueueJr in forum Uncategorised MetalWorking Machines
    Last Post: 07-03-2012, 01:46 AM
  4. mach3 spindle dro not working, spindle speed changing while jogging and running code
    By jasminder in forum Mach Software (ArtSoft software)
    Last Post: 02-23-2011, 07:12 AM
  5. Replies: 4
    Last Post: 10-15-2010, 07:10 PM
