586,352 active members*
3,402 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 0M Parameters 9000-9899 description
    Apr 2007
    5
    Hello,
    I lost the parameters at a Johnford machine center with Fanuc 0M control.
    I upload the parametrs from a similar machine. I would like to know what are the parameters from 9000-9899 becaude I can't find any description for them.
    Thanks in advance
    24222
    The 0M has 900 option parameters, or do you mean the 9000 macro's?
    There is a parameter where you can lock them out to avoid accidental erasure.
    bit 4 of parameter 0010.
    Al.
    Albert E.
    Apr 2007
    5
    Hello again,
    I mean the parameters 9000-9899. Not the macro programs for the tool change (O9000----) or the option parameters 900---.
    In the manuals for this control I found no descriptions for these parameters but there were in the back up file for the machine and also at the printed sheet.
    I have to notice to you that the control has C.A.P. programming.
    My main problem on this machine is that the machine does not execute tool change. I load the macro program i had backup (O9000) but the control does not execute the comand T4 for examble.
    There is not need to write M6 just the T code.
    I also checked the parameter 40#5 so the T code calls program O9000 but with the comand T the cycle start button remains green and the machine don't get in the O9000 macro.
    That is why I need to know what are these parameters, maybe there is a conection with the tool change
    Thanks again
    Apr 2007
    5
    Hello,
    finaly I solved my problem.
    Parameters 9000-9899 are for C.A.P. programming. The parameter for tool change is 9898 and this parameter was my problem.
    Thanks a lot
    Sep 2019
    Quote Originally Posted by nik_chris View Post
    Hello,
    Thanks in advance
    Good afternoon!
    I wonder if you have the parameters of this machine, because I also have a jonhford fanuc OM and lost my parameters.
  1. Mazatrol M32 Machine parameters description.
    By EliseoMonteverd in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-27-2023, 08:57 PM
  2. FANUC 15M Parameters 9000 how to enter?
    By posedi in forum Fanuc
    Last Post: 09-26-2020, 01:24 PM
  3. description of machine parameters for Mazatrol T1
    By mastercuthead in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-18-2008, 01:25 AM
  4. 11M 9000 parameters
    By chuy in forum Fanuc
    Last Post: 07-25-2007, 03:03 PM
  5. Replies: 2
    Last Post: 02-15-2007, 03:10 AM
