586,076 active members*
3,865 visitors online*
    Jan 2013
    5
    Wells index 420 with Heidenhain convert to Mach 3
    I just bought this machine, it has large servo motors and three servo dynamics drivers. I believe that there is one step and one direction signal for each axis. Can I tap into the Heidenhain switches that issue these commands on the control panel? I plan to add an A axis. Which 4 axis breakout board is best to work with. Should I go with USB or printer port card? Which is best? Thanks.
    Feb 2009
    6028
    Post what drives you have. I remember most servo dynamics requiring +/- 10 volt for direction, or direction and 0-10volt for speed.
    Jan 2013
    5
    Servo dynamics controller .... Picture was worthless here s the model no of driver
    SD4-1525-101-3 Serial no 294 Thanks for the reply
    Jan 2013
    5
    I could not figure out how to get mach3 (step and direction digital output) to work with analog (+or- 10 volt) drives. The answer is to replace the old brush type dc servos with newer brushless motors. The newer drives such as compumotor GV,GV6,GVK drives receive digital (step and direction signals. That's a lot of retrofitting but it will be worth it! Lots of ebay $ too. I'm looking into running this Bridgeport + size machine on about a horsepower per axis (x+y) using a smaller frame motor and about a 2 to 1 belt drive. Does this sound sufficient? I get all bogged down in hp, oz.-in, NM, etc etc.
  1. wells index 700
    By tailormade in forum Machinery Manuals / Brochures
    Last Post: 08-25-2012, 02:43 PM
  2. Wells Index conversion
    By Dave in forum Uncategorised MetalWorking Machines
    Last Post: 03-03-2010, 10:45 AM
  3. Wells Index updat
    By dschultz2009 in forum Want To Buy...Need help!
    Last Post: 08-24-2009, 10:07 PM
  4. Wells Index Mill
    By honda in forum CNC Machine Related Electronics
    Last Post: 09-07-2008, 07:17 PM
