586,219 active members*
3,362 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > I will shortly have my new(old) bridgeport R2E3 running. What do I need for tooling?
    Mar 2013
    I have a kwik switch 200 installed on machine.
    Should I change that to something else before I buy any tooling?
    The people I bought the Bridgeport from gave me about 20 various sized end mills and stuff.
    And what would be the best vice for me to invest in? I will buy it used (I am on a retirement fixed income :-)
    At this point I don't know what I want to mill but it will most likely be aluminum , steel and stainless steel.
    I am so new to this I don't even know the proper terminology for this question.
    Apr 2006
    87
    Kwik switch 200 tool holders can be expensive. Changing isn't cheap either. What size shank is your end mills? Ebay has a bunch for sale, just type in "kwik switch 200" to search. It usually starts around 40 bucks a tool holder (and up). If you need 1/2" or 3/8" tool holders, I can probably get you some cheap.
    Aug 2009
    Your best bet is to buy a couple of different sized collet holders and just pick up what ever size collets that you might need. The collets can be found in assorted sizes on Ebay for pretty cheap. A lot of us have extra collet holders that can be had at reasonable prices.
    Changing spindles is pricey and a fair amount of work.
    Bill
    Mar 2013
    Thanks! I went to ebay a suggested and got what I need at least to start :-)
    Apr 2010
    486
    A Kurt would be ideal, assuming that one would ever come up for sale. Highly unlikely.
    There are a couple of good Kurt knockoffs out there.
    Tom
  1. Bridgeport R2E3 Problems
    By TWKundrat in forum Bridgeport / Hardinge Mills
    Last Post: 03-20-2009, 03:07 AM
  2. Bridgeport R2E3
    By toadjammer in forum Bridgeport / Hardinge Mills
    Last Post: 02-19-2009, 06:25 PM
  3. bridgeport II r2e3
    By whaley in forum Bridgeport / Hardinge Mills
    Last Post: 01-06-2008, 09:13 AM
  4. R2E3 Tooling
    By dfmiller in forum Bridgeport / Hardinge Mills
    Last Post: 05-29-2005, 10:51 PM
  5. Bridgeport R2E3 with Boss 8
    By John Bennett in forum Bridgeport / Hardinge Mills
    Last Post: 04-06-2005, 04:06 PM
