586,089 active members*
3,933 visitors online*
IndustryArena Forum > CAD Software > Rhino 3D > Generate G code from rhino file
Results 1 to 15 of 15
    Apr 2005
    47
    Using Rhino v4.0 and I have created a 3d part. What I need to do now is convert this to gcode. I have tried gcode 2000, a plug-in called "gcode", and a few others. What I am getting out is limited 2d or just junk. I am going to try vetric cut3d and see if that can do the job.
    What are others using to produce gcode? I'm also not sure if my DXF files are preventing these other programs from working right. I'll take any ideas and here is the file I made.
    Apr 2005
    47
    Here is the file:
    35538
    In addition to Cut3D, you might also want to look at MeshCAM. For free, there's Freemill, but it's pretty limited. There are numerous other CAM programs costing much more money that will also work.
    Apr 2005
    47
    HA! I'll try this up load again:
    35538
    Try zipping it if it won't upload.
    Apr 2005
    47
    I zip the last one but I'll give it another go....
    Attached Files Attached Files
    Jun 2003
    2103
    Quote Originally Posted by mredican View Post
    mredican what diam tool bits do you want to use, what is your origin you want to use?
    I am the reseller for Madcam, a cam plugin for Rhino and I would be glad to demo the software for you.
    I would suggest roughing with a 1/2" ball endmill, do a finish with a 1/2" ball endmill, do a remachining with a 1/4" ball endmill and a final remachining with a 1/8" endmill. I haven't looked at the depth of the scroll yet, but if it isn't too deep, a pencil tracing with a 1/16" endmill would finish it out.
    Mike
    No greater love can a man have than this, that he give his life for a friend.
    Jun 2003
    2103
    Hey Gerry since you brought the zipping thing up, can you make it happen that we can upload native Rhino 3dm files? As many Rhino users as there are it would be nice to not have to zip those files, unless of course they were too large!
    Mike
    ps or do we need to nag Paul?(wedge)
    35538
    Paul.
    Jan 2004
    3154
    mredican - you can try a product called RhinoCam as well. It isn't free though.
    In the subject of uploads you can add SolidWorks files to that wish list as well.
    www.integratedmechanical.ca
    Apr 2005
    47
    I am considering RhinoCAM.
    I have fumbled with low end CAD to try and save a dime for a long time until I got to the point where I closed my eyes and bought Rhino v4.0. I am sooooo glad I did and I kick myself for not doing that faster. I just need to recover a bit if you know what I mean
    I am wondering if my problem is the way I made my cad file? The project is a surface that is elevaded 0.22 inches on the Z. Do I need to convert this object into a solid or do I need to layer the object? I can generate gcode from simple dxf, like single lines and curves, in varrious z points.
    Nov 2004
    436
    Rhinocam
    With Rhinocam, you do not need to have solids to machine. I machine from surfaces all the time, with excellent results. It is also worth noting that Rhinocam converts all Nurbs surfaces to mesh while it is generating the toolpath. Whatever surfaces are higher (when looking at the Top Viewport) will be the surface the toolpath machines (this is for 3-D toolpaths). Of course, you can also machine directly from curves, using the 2.5D machining strategies.
    Hurry up and recover from your expenditure, you really need to get your hands on this great software. Then, you will only be limited by your creativity.
    Cheers,
    Rob
    Apr 2005
    47
    Well guys, I did it. I now have RhinoCAM! I'm sure I'll be back here to ask some questions. I work with it tonight and give an update on Saturday.
    Apr 2005
    47
    Wow! Spoiledbrat thanks for pushing me over the edge. I can't believe how seamless the process is from design to machine code. This is great!
    matt
    Nov 2004
    436
    You will not regret that purchase, not ever.
    PM me if you have any questions about Rhinocam, I will be glad to correspond and help out however I can.
    Rob
  1. scan part and generate cad code?
    By ATV in forum Uncategorised CAM Discussion
    Last Post: 02-14-2008, 07:56 PM
  2. How to generate g-code to mill flat surface
    By pminmo in forum G-Code Programing
    Last Post: 09-10-2006, 06:33 PM
  3. Generate G-Code for end-milling operation
    By vijaychd in forum G-Code Programing
    Last Post: 06-02-2005, 09:46 AM
  4. Best way to generate code?
    By jderou in forum BobCad-Cam
    Last Post: 09-29-2004, 02:37 PM
