Hello guys,
I'm pretty new at this thing called CNC but i have a big problem
one input pin ...11 to be exact is in a different than all the others ...meaning it says i'm allays connected to GND (it's the port where i put a home switch on my machine) the one indicated by the manufacturer of my board ....last night i was playing with limit switches and they all worked fine (checked by mach3 diagnostics page )...today ...bam ...that pin is working vice verso than the others.
i connect pin 11 to gnd ...nothing happens ...no blinking led on mach3 screen ...change state to actve hi/low ...i juct cant get it to work, it-s like he dose not whant to take any signal ...can you give me a suggestion????
P.S. i forgot to mention that all the time the controller board was removed from the cable and the state of the input pin 11 did not changed .
