586,100 active members*
2,627 visitors online*
    Nov 2009
    79
    DRO for 3in1 machine
    I previously posted this in the Smithy forum, but got no response.
    I have a 3 in 1 Mill/Drill/Lathe that I would like to add some sort of DRO to. Since I have practically no money, I am looking at the Grizzly
    H8176 Cutting Depth Digital Readout for G0516
    at $159.95 +SH
    This is similar to one that Little Machine sells but appears to have solved the interference between the displays that keeps the compound from turning around.
    Does anyone have any experience with this display and or the installation on the Enco, a Harbor Freight, the Smithy or other similar 3 in 1 machines?
    My machine (see photo):
    Model #328-1308
    Enco 3-in-1 Machine;
    Swing Over Bed: 16-1/2";
    Distance Between Centers: 15-3/4";
    Cross Slide Travel: 4-3/4";
    Spindle Bore Diameter: 3/4";
    Spindle Nose Designation: 3MT
    Low Price: $1,797.98 ea
    As far as I can tell the overall dimensions of the cross and compound are similar and I do have a milling machine to modify the mounts if it is possible actually install this on my machine.
    Oct 2006
    210
    The best thing to do is to buy some of those cheap Chinese scales on eBay with the remote display and make your own mounts. Like these here:
    12" Digital Readout Scale Bridgeport Mill Lathe DRO Table Linear Magnetic Remote | eBay
    I don't know about a diameter function for the lathe, but simply multiplying by 2 isn't a big deal for most people.
    Nov 2009
    79
    Found a posting someplace on the net that points out that these do not have any form of backlash compensation. They would not be that useful. I will be going with sliding scales. just need to find the money.
  1. Craftex B2229 3in1 Mill-Lathe-Drill Heat issues.
    By trunner in forum Uncategorised MetalWorking Machines
    Last Post: 01-07-2011, 09:35 AM
  2. Convert HF RE: 44142 3in1 lathe or sell and buy a G0602 ??
    By David Bord in forum Benchtop Machines
    Last Post: 02-04-2010, 12:19 PM
  3. Buying a 3in1 Plasma/Tig/Stick welding machine
    By kheri in forum Waterjet General Topics
    Last Post: 05-13-2009, 11:27 PM
  4. Enco 3in1
    By davidlee in forum Benchtop Machines
    Last Post: 01-03-2007, 04:25 AM
  5. harbour freight 3in1 machine
    By trubleshtr in forum Mini Lathe
    Last Post: 12-01-2004, 04:55 PM
