586,082 active members*
3,593 visitors online*
    Apr 2013
    Micro Milling
    Has anybody had experience using cutters 0.010" and below in steel.
    I'm doing a job and breaking a few cuuters. I have a 30000rpm spindle
    and using oil mist coolant. Any advice would be welcome.
    Nov 2012
    .0005" d.o.c.
    4 i.p.m.
    I have 50,000 rpms and vary between .0002" doc and .5 ipm to .001" doc and 5 ipm.
    Jan 2012
    Yes. What kind of cutters are you using? What spindle are you using? What is its runout and did you measure to verify this? What type of steel?
    Also list all the parameters you used for the machining.
    Carbide all the way. TiAlN coated preferred (yes you can get them that small say from Micro100). AGreed with the 0.0005" DOC. 0.0005" radial stepover. slow feed. Use fancy entry moves if available but plunge entry probably makes no difference.
    Apr 2013
    Thanks for replying
    The spindle is HSK F63 in a Makino
    Tool holders - Big Daishowa Mega - Runout 0.001mm checked
    Tool - Garr Tool 11550 220M 0.010"
    Steel - Impax Supreme approx 38 HRC
    I was feeding at 0.8"/min and 0.0002" DOC, 50% step over and experience alot of burring.
    Do you think air blast cooling is better than oil mist, the swarf seems to stick
    with oil mist and possibly causes the cutter to break.
  1. PCB milling with Lumenlab Micro cnc machine
    By Jamgee in forum South Africa Club House
    Last Post: 06-02-2012, 02:58 PM
  2. Milling Copper (on a micro scale)
    By ME-Student in forum Material Machining Solutions
    Last Post: 10-08-2010, 08:45 PM
  3. Micro Mark mini milling machine
    By simila95 in forum Benchtop Machines
    Last Post: 10-27-2009, 08:58 PM
  4. Need Help to find micro milling service shop
    By looking9 in forum Employment Opportunity
    Last Post: 03-12-2008, 03:30 AM
  5. White Paper: Highspeed milling with micro-tools
    By HighSpeed in forum News Announcements
    Last Post: 03-03-2004, 03:29 PM
