586,069 active members*
3,445 visitors online*
Results 1 to 14 of 14
    Feb 2010
    Biesse 321r NC 481
    Hi all,
    My battery failed over the long weekend lost all machine data programs etc etc !!!
    I have disks with everything on them but need to know the process of putting the info back into the machine.
    Feb 2009
    15
    send me your mail, i will email to you the steps.
    Apr 2013
    Biesse 18. CNI NC481
    I have the same problem like madmuz. I have disks too. But i haven't how load it. Do You help me knap?
    Jun 2015
    Re: Biesse 18. CNI NC481
    Hi guys. Me too. Just acquired a Rover 18 which I saw working before I bought - and the internal battery has died and lost all the machine data etc. I have the disks but can't find a way of reloading the data. Any help much appreciated.
    Dec 2014
    Hi. I've got machine data.
    Sep 2015
    Hello Friend. I'm interested in whether and how they could send me a disk with parameters for biesse rover 18 computer is nc481. Because I have the same problem as you do with the battery, and I have replaced the same just missing parameters. Sorry for my bad English,
    Thanks in advance!!!
    Re: Biesse 321r NC 481
    Hola Madmuz
    i am from chile , i have one big problem with machine rover 321R error 332 333 no position axis , if posible failure electronic card Rcx2 ?
    If you had a similar fault podriar help giving an advice
    best regards
    Oct 2015
    Need help !
    When I turn on Rover 321 nc481 on screen appears "Bdos Err On C: Select" and that it I cant even hit enter nothing happens! Before that few days it said that the disc A is not ready (floppy) but my diskette is valid.
    What i need do to?
    Oct 2015
    I see that you have same problem. My battery die too so I replace but still doesnt boot up.
    Same error A floppy, but floppy is working.
    What can be.
    Can anyone send me some solutions on [email protected] ?
    Feb 2017
    Hi All,
    I also have a Biesse Rover 321R with a NC481 controller.
    Battery died last week and I have replaced it with a genuine Biesse part.
    Machine now boots and everything is reset and in Italian.
    I don't have the original set of Floppy Disks that came with the unit.
    Can anyone help me out with a copy?
    Have contacted Biesse parts Australia but haven't heard anything back.
    Cheers
    Mar 2017
    Hi
    We have a Biesse a NC481 controller.
    The battery died and I replaced it.
    Transferred machine data from the floppy disk but did not transfer it.They are all still at zero.
    I need help please.
    Feb 2020
    Question Re: Biesse 321r NC 481
    hola, soy nuevo y necesito ayuda mi rover 321 r de biesse controlador cni nc 481 se quedo sin bateriaperdiendo todos sus datos. Al cargar los drivrers se me colgo y no me deja hacer nada, solo arranca boot y me deja errores de falta de controladores ES803 ES58 S023010 S022999 S011 AD58 AV21 AV20 I011. Nesecitaria saber de alguien con la experiencia en carga de archivos plc idioma y valores generales de maquina. Gracias
    Feb 2020
    hola,e visto que hace unos años te ayudaron con un problema similar al mio mi rover 321 r de biesse controlador cni nc 481 se quedo sin bateriaperdiendo todos sus datos. Al cargar los drivrers se me colgo y no me deja hacer nada, solo arranca boot y me deja errores de falta de controladores ES803 ES58 S023010 S022999 S011 AD58 AV21 AV20 I011. Nesecitaria saber de alguien con la experiencia en carga de archivos plc idioma y valores generales de maquina. Gracias
    Jul 2022
    Hi everyone. I have an old 321R with CNI481 contrôler.
    The machine today boots but the axis are all in 0.00 and the machine refuses to work.
    Error code :
    S011
    S020101
    S023872.
    Anyone knows how to fix this ?
    The machine boots normally.
    Is the battery dead ?
    What steps should i follow?
    Thanks everyone ????
  1. Biesse , Rover 321R
    By lamicron in forum Biesse
    Last Post: 05-27-2013, 01:42 AM
  2. Controller for Biesse Rover 321R
    By grc in forum Commercial CNC Wood Routers
    Last Post: 07-31-2009, 12:11 PM
  3. Biesse Rover 321R questions
    By bigz1 in forum CNC Machining Centers
    Last Post: 07-18-2009, 01:37 PM
  4. Help needed Biesse 321R
    By StillMakingCabinets in forum Australia, New Zealand Club House
    Last Post: 05-06-2009, 10:30 AM
  5. Biesse 321R power supply
    By abkdf in forum CNC Machining Centers
    Last Post: 04-20-2009, 10:54 PM
